View Poll Results: What pressure do you set your tires at?
No clue, I don't check the pressure
1.96%
32 PSI
5.88%
32-35 PSI
15.69%
35-40 PSI
21
41.18%
40-42 PSI
13
25.49%
42-45 PSI
1.96%
45 PSI and above
7.84%
Voters: 51. You may not vote on this poll
[poll] What tire pressure do you use?
Old Jan 17, 2008 | 09:27 AM
chris_h's Avatar
Default Re: [poll] What tire pressure do you use?
Originally Posted by haroldo
How about...
What PSI do you use
  • MFR recommended PSI
  • MFR recommended +(1-3) PSI Front and Back
  • MFR recommended +(1-3) PSI (less 2 PSI in the rear)
  • MFR recommended +(4-6) PSI Front and Back
  • MFR recommended +(4-6) PSI (less 2 PSI in the rear)
  • etc
Are you equating "MFR recommended" with the max pressure printed on the sidewall?
Old Jan 17, 2008 | 09:31 AM
rmorrow's Avatar
Hmm.. i assumed he meant the recommended pressure printed on the label inside the driver's door pillar.
Old Jan 17, 2008 | 09:34 AM
haroldo's Avatar
...or on the sidewall of the tire?
That would eliminate the difference between the various tires, no?
Old Jan 17, 2008 | 10:03 AM
chestr's Avatar
You should also add a final category for "oh yeah I should check my tire pressure soon!". Hehe. I know I'm in that one, I keep letting it slip. Been a while since I last inflated my tires a bit.
Old Jan 17, 2008 | 10:07 AM
chris_h's Avatar
I think that is what chestr had in mind, and makes more sense by my way of thinking. Otherwise you have to do two polls, one for those whose car has the michelins, and one for those whose car has the bridgestones. Otherwise, the numbers become mixed and less useful.
Old Jan 17, 2008 | 10:11 AM
rmorrow's Avatar
There is no recommended pressure on the sidewall of any tire I've seen - only a maximum. The only recommended pressure is the one on the label usually found on the B pillar of the car, and is unrelated to the tire manufacturer or type. That is the only standard figure that I can see any discussion of tire over-inflation referring to.
I can see two figures of interest coming out of this:
No. of pounds over recommended pressure for the vehicle (32 lb. for the 2007 TCH, front and rear).
No. of pounds under the maximum pressure for the tire.
Old Jan 17, 2008 | 12:00 PM
haroldo's Avatar
What is Mich PSI?
What is Bridgestone PSI?
Old Jan 17, 2008 | 12:44 PM
Fooshe's Avatar
look on the inside of the drivers door and always use the Mfg. recommended pressures...unless you are loading the car with people or luggage, then follow the table in the owners manual.
Old Jan 17, 2008 | 01:13 PM
haroldo's Avatar
But, isn't there a difference between the tires recommended pressure?
I don't want to be difficult, but, if I create a new poll, I want to do it right (this time).
Old Jan 17, 2008 | 02:33 PM
chestr's Avatar
I think the car just states a generic "recommended" pressure, but the different tires can safely handle different tire pressures. I believe (vague memory from existing thread somewhere) the Bridgestone max is something like 44 psi, and the Michelins are more like 50? But Toyota probably still recommends 32 regardless of tire brand/model.
So the scale from "recommended" to "max" is different between the two tires. I'd say try a %age scale maybe but that's way too much math for most of us for casual posts lol.
