P0a94
Old Apr 29, 2020 | 12:47 PM
Omar Ajarmaa's Avatar
Default P0a94
I have camry 2009 it stoped alwyes after 20 min on highway. And give me code p0a94 dc dc converter. I changed many parts. Nothing happens. The problem still. Any body solved it. Please tell me.
Thax
Old May 12, 2020 | 11:24 AM
Kayden Bathory's Avatar
Default Re: P0a94
Thax
What parts have you changed so far? Im curious as I have the same issue. tho mine is an altima, it uses the same Toyota system. I replaced the ECU, Inverter, and transmission fluid, I also see the coolant pump working in the inverter (coolant being pushed around) I still have the same problem.
Old May 12, 2020 | 01:57 PM
Default Re: P0a94
You need the detail code, P0A94-XXX
vasili
Jan 3, 2025 08:24 AM
mfalk22
Jun 16, 2019 06:04 PM
accent2010
Mar 22, 2019 08:49 PM
vasili
Toyota Motor Corporation
Sep 16, 2015 06:11 PM
talgat_duisenov
Apr 30, 2013 09:54 AM
