Overriding hybrid navigation system
Old Mar 17, 2008 | 05:00 PM
  #41
Tideland Prius's Avatar
Default Re: Overriding hybrid navigation system
Originally Posted by schmidtj
I didn't think the Prius had the Hi-Res NAV that the Camry/Lexus have. If that's a Camry DVD you have that might be the issue?
The 06+ Prius have the new hi-res MFDs.
flyingtux, make sure you have the right disc for the right MFD. There are two discs - one for the older screen and one for the new one.
Old Mar 18, 2008 | 01:26 AM
  #42
Flyingtux's Avatar
I can't even get a copy of my original disk, unmodified, to work. It goes through the loading process ok, but then says "unable to read data. Check if map DVD is correct."
Old Mar 18, 2008 | 01:27 AM
  #43
Flyingtux's Avatar
Does anyone have a 2006 Prius with an original U40 464210-0701 Ver 5.1 disk in that they where able to get working?
Old Apr 1, 2008 | 06:29 PM
  #44
schwachs's Avatar
Should these hacks work on a Highlander Hybrid as well - 2005?
Thanks!
Old Apr 2, 2008 | 07:51 AM
  #45
mikieboyblue's Avatar
Thanks!
Maybe, you'll have to give it a try. I don't think anyone here has tried.
Old May 4, 2008 | 12:45 AM
  #46
whitslack's Avatar
I have a 2006 Prius with original Toyota DVD U40 464210-0700 ver.05.1. I was able to make a working backup of my DVD.
My DVD drive is a Lite-ON SHM-165P6S (firmware MS0R).
The media I used is Memorex DVD+R DL (media ID: RITEK/D01).
I found the number of sectors on the original Toyota DVD: (it was 3797424)
Code:
isoinfo -d dev=/dev/dvd
I extracted an image of the original Toyota DVD:
Code:
readcd dev=/dev/dvd sectors=0-3797424 f=464210-0700.iso
I set my drive to write DVD+ media with DVD-ROM book type:
Code:
dvd+rw-booktype -dvd-rom -unit /dev/dvd
Then I burned a copy of the disc:
Code:
growisofs -dvd-compat -Z /dev/dvd=464210-0700.iso
The copy loaded up in my Prius without a hitch. So now I can keep the original inside and out of the heat.
lebloom
Aug 31, 2010 10:35 PM
inetport
Apr 16, 2009 08:54 AM
surfer1966
Aug 22, 2008 10:40 AM
Paulgw
Nov 22, 2006 06:31 AM
davwick
Toyota Highlander Hybrid
Apr 17, 2006 08:53 PM
