Outside air or recirculated air mode switch
Old May 14, 2008 | 11:07 AM
haroldo's Avatar
Default Re: Outside air or recirculated air mode switch
I always thought cooling cold air (from the cabin) used less energy than cooling warm outside air, or am I wrong?
Old May 14, 2008 | 11:24 AM
chestr's Avatar
No, you're right, but if there's no climate control in use, it's not cooling anything.
Old May 14, 2008 | 11:31 AM
coolshock1's Avatar
Driving in stealth mode
Originally Posted by chestr
Does it actually make a difference in mileage? My assumption would be the difference is just an "open" vs "closed" venting state. I suppose "open" could increase drag somehow, depending on how it was implemented... Admittedly using AC/heat, or even just the fan, vs not using is a choice people make based on personal preference vs mileage--I'm mostly comfy with windows/roof open when it's hot out and if I need more than that I can pop on the AC for a bit.. and winter unless I'm unusually cold or need to defog/frost my windshield I mostly figure I'm good as long as I'm out of the wind, hehe. So I don't have the fan on in my car most of the time because I think it's unnecessary. But recirc power usage, I can't imagine there would be any. In fact I think it's kind of foolish that they didn't have an extra condition for the recirc being on automatically, namely that the fan should be on. I do turn mine to recirc sometimes for particularly stinky circumstances, but otherwise why on earth would I want to have trapped air in warm weather if I'm not using the AC? Recirc doesn't dehumidify, AC does. Recirc by itself is mostly dumb as far as I'm concerned, except specific (as I said, stinky) circumstances (exhaust, skunk, etc).
Not adding a disagreement but and addition.
Doesn't recic intesify the eefectsm of what you are trying to achieve. If it's winter and you turn the heat on doesn't it cause the system to blow harder, hotter and also keep the cold air out? If it's summer and you have the A\C on doesn't it do the same thing only make it cooler and keep the heat out?
Old May 14, 2008 | 11:38 AM
chestr's Avatar
Sure, but as I said that's only relevant when you're actually using the climate control at all. Heating, AC, the fan has to be _on_ or none of this matters, the only effect of recirc when the fan's not running is that it prevents outside air from getting in. When it's hot, the car's already roasting when I get in the car, the air outside is in fact _cooler_ than the air in the car, therefore (without using AC, remember) having the recirc on is eliminating one way of cooling the car--and if it's raining or something, probably the only way, as rolling down windows is less of an option. And I rarely use either heat or AC, the vast majority of the time for me, the fan is completely off. Recirc is not going to help me cool my car down then.
In winter, one issue I've had where recirc may or may not be a factor (hard to tell since I don't know what it does when I shut down) is that a completely closed car is more likely to end up with frost on the _inside_ of the windshield after a cold night, especially if you haven't been using AC (as dehumidifier). All the (relatively) humid air is trapped, condenses on the windshields, freezes. Sometimes to ensure the humidity can escape I've left windows (or roof) open in the winter, when I know it's safe.
Old May 14, 2008 | 11:51 AM
coolshock1's Avatar
I agree. I only want it on when I want it on.
Old May 14, 2008 | 12:24 PM
bmgoodman's Avatar
I had mine changed by the dealer and I'm happier with it. However, it still turns RECIRC off on its own sometimes, especially when starting the car. This is a minor nuisance in winter. In summer, it's fine because when the car is roasting inside, the fresh air is better. Once it cools a bit, I can turn on RECIRC again.
In any event, it's the closest I can get to controlling the setting myself.
Old May 15, 2008 | 11:10 AM
acco20's Avatar
The last time I switched to recirculate manually, I think a bus was in front of me, I forgot I had changed it and the next day I noticed it was still in that mode. That tells me that it stays where you put it until you either switch it back or hit auto. I think you should hit auto to switch otherwise I guess it would stay at outside air even if the auto would use recirculate if it could. ???Did I say that right??? JMHO.
mda1224
Sep 23, 2008 10:07 AM
UWAdventurer
May 16, 2008 07:25 PM
lars-ss
Toyota Highlander Hybrid
Feb 21, 2007 05:29 AM
drmperalta
Oct 9, 2006 10:25 AM
