noise under hood after car is off
Old Mar 19, 2020 | 03:08 AM
bodenl1's Avatar
Default noise under hood after car is off
Hello all -
2012 Camry Hybrid XLE, apprx. 120000 miles
I apologize if this has been discussed before - I searched but was unable to find this problem.
Last night after my wife got home, a couple hours after the car was turned off I noticed a whirring or humming sound coming from the front engine area. When I opened the hood it sounded like it was coming from the back left as I'm facing the car. I tried to start the car but it did not respond. This morning when I tied to start it was completely dead, no lights or anything on the dash.
We've had zero issues with this car in the past. Could it be a dead 12V? battery problem? Can I safely jump this battery? It seems that I was told that jumping the battery (not the large hybrid battery) on a hybrid is unsafe. Any help is much appreciated.
thank you
Old Mar 19, 2020 | 08:06 AM
Default Re: noise under hood after car is off
Originally Posted by bodenl1
Hello all -
We've had zero issues with this car in the past. (1) Could it be a dead 12V? (2) battery problem? (3) Can I safely jump this battery? (4) It seems that I was told that jumping the battery (not the large hybrid battery) on a hybrid is unsafe. Any help is much appreciated.
thank you
(1) If it's the original battery from 2012, almost certainly. If it's more than 2 years old, probably.
(2) If you mean hybrid battery problem, symptoms are not consistent with that.
(3) yes. Instructions are in the owner's manual
(4) You were lied to, or you heard it wrong. Again, instructions for jump starting the vehicle are in the owner's manual.
Owner's manual:
https://techinfo.toyota.com/techInfo...chinfoPrelogin
Section 5-2, Page 461
Weak/failing 12V can cause extremely erratic behavior. Proper diagnosis of any issue begins with confirming the 12V system is fully operational. Yours sounds like the 12V is dead. Replace 12V.
Rawxst4r
Oct 18, 2020 03:59 PM
Baker
Oct 17, 2018 05:32 PM
Jacopo
Aug 8, 2011 11:02 AM
castleman
Nov 8, 2009 04:28 PM
cdbrow1
Jul 18, 2005 07:07 PM
