Navigation, adding it on afterwards
Old Sep 15, 2006 | 02:57 PM
  #41
Loonbeam's Avatar
Default Re: Navigation, adding it on afterwards
From what we could tell it wasn't a matter of the presence of the ECU, simply that the wiring to connect the appropriate unit (not sure which) to the Nav display was not installed if the nav display wasn't and that might require some specialized work.
The tech we spoke to THOUGHT there might be some kind of 'translator' module needed along the wiring as well that was built into the pre-installed harness, but did not have one available to look at, so that is still unconfirmed.
Old Sep 15, 2006 | 03:07 PM
  #42
elmo's Avatar
I think I have all the connections required worked out on paper. The steering wheel controls/mic etc... will work but the wires need to be moved to a new connector. There's no intermediate modules required for the energy screen to work as far as the hybrid wiring diagrams show. I'm also going be ge adding a backup camera to my nav as well. Hopefully I'll have time next week to hook mine up.
Old Sep 15, 2006 | 05:30 PM
  #43
stinger123's Avatar
The wires that need to change positions, I believe are shown in the attached diagram.
Elmo, which camera are you using ?
File Type: doc
Old Sep 15, 2006 | 08:33 PM
  #44
elmo's Avatar
The changes in your diagram will work but it will not enable the energy screen, those are missing. I'm not sure why the splices are required on the top of the page. Hopefully I've figured that out. There're 4 more connections required for the energy screen. I'm guessing the person that drew that had a reg. camry. I'm thinking about using the camera off the ES350 or Sienna. I've got to go look at one myself to see how it'll fit. I'll also be installing the vias tech ipod interface at the same time. That's just plug and play.
Old Sep 20, 2006 | 10:53 PM
  #45
elmo's Avatar
Finally got mine installed and working on Monday. Everything works except for the energy monitor. The energy screen isn't working even with the extra lines connected. Maybe the car's ecu needs to be aware of the Nav before that'll work? The vais tech ipod interface works well with the nav as well.
Old Sep 21, 2006 | 03:56 PM
  #46
stinger123's Avatar
Hi Elmo,
Glad that most of the features work. My unit is still only partially connected.
Did you manage to find the correct plugs for the nav unit ?
There may be help available from Toyota Canada ! The nav is now shown as a dealer installed option, it is not clear if the energy screen is enabled.
If it is it would be nice to get a copy of the install kit instructions.
Does anyone know someone who works for Toyota ?
If we are lucky there may even be a wire harness adapter in the kit.
Old Sep 21, 2006 | 04:11 PM
  #47
cohort's Avatar
let us know if you get energy screen working please
Old Sep 21, 2006 | 08:03 PM
  #48
elmo's Avatar
I just ordered 2 F13 connectors today from a US dealer. The Canadian dealers are unable to order that connector. Stinger, where did you see that the NAV is now a dealer installed item?
Old Sep 21, 2006 | 08:09 PM
  #49
elmo's Avatar
Stinger, I just noticed that the Nav demo on toyota.ca is also missing the energy screen. If you hit the "info" button, there's an icon missing for the energy screen.
Old Oct 17, 2006 | 10:33 PM
  #50
ebjustin's Avatar
Stinger, any updates on the nav install?
