Nav Owners - Fixed or Rotating Map?
Old Jan 12, 2007 | 02:24 PM
TKCamry's Avatar
2007 Toyota Camry Hybrid
Default Re: Nav Owners - Fixed or Rotating Map?
Heading Up. Much easier to follow turns on the map that way.
Old Jan 12, 2007 | 02:51 PM
lucky07's Avatar
i allways use heading up, north up takes lot of attention. and i dont prefer it at all
Old Jan 12, 2007 | 04:39 PM
meerkat's Avatar
Me 2
Heading up makes more sense to me since the turns are easier to anticipate and pre-route,
Old Jan 12, 2007 | 05:33 PM
abward's Avatar
Heading up for me.
If you are relying on the computer to tell you which way to go, why would you care which way happens to be north? It is irrelevant information.
Old Jan 12, 2007 | 09:09 PM
kris's Avatar
I just learned something new today. Having to twist my head to read the screen was starting to bug me.
Thanks for pointing out something that should have been obvious.
Old Jan 13, 2007 | 05:35 AM
juicius's Avatar
I almost always use north-up, more or less because that's how paper maps (remember those?) are oriented and I'm used to using them. I don't find turning confusing at all. I do sometimes use heading-up as a part of split screen NAV. The left side is zoomed out at around 2 miles and north-side up and right side is zoomed in and heading-up. Like many people said, I use that setting in the residential section of an unfamiliar area.
Old Jan 13, 2007 | 11:33 AM
alan_in_tempe's Avatar
Veracitorian Muser
I almost always use North-up.
When I approach a turn with directions given by the computer, it goes to split screen with a blow-up of the intersection and the maneuver I am about to execute, and that split is always Heading-up.
I do not find North-up confusing, even with the split in the other mode, and it helps be keep a sense of which way is north when I am in unfamiliar territory.
-- Alan
Old Jan 14, 2007 | 01:12 PM
skata's Avatar
I, too like the north up orentation. But I also like to navigate heading up. So, I use the split-screen all the time.
The left side is a close up (to the level where all streets show) and oriented to the direction I am driving. The right side is north-up and zoomed out where I can see pretty much a large city's highway infrastructure across the entire screen.
Sorry I don't have the settings available to put down here since I never change it and don't display the zoom level.
Sooty
Jan 6, 2012 05:08 AM
tharvey
Aug 2, 2008 07:04 PM
rmorrow
Sep 25, 2007 07:21 AM
wordsworth03
Mar 17, 2007 03:53 PM
Supercharged
Jan 13, 2006 08:49 AM
