More Motor and Less Engine?
Old Aug 25, 2006 | 07:41 AM
  #31
Droid13's Avatar
HSD Organic Interface
Default Re: More Motor and Less Engine?
Originally Posted by schmidtj
Isn't the TCH traction battery sort of "L" shaped? Verticle against the back seat and also flat under the far front of the trunk? I'm going on the memory of some pics I saw somewhere. I could be wrong on this.
J
What you've seen against the back of the seat is the ducting for the battery cooling system. It draws air from the cabin thru a vent on the rear deck down to the battery via fan if the battery needs cooling.
Old Aug 25, 2006 | 07:54 AM
  #32
schmidtj's Avatar
Keeping Toyota Solvent
This is the picture.
The battery pack is flat.
Actually it looks more like two Prius batteries side by side.
Also it looks like it lays as somewhat of an angle versus
totally flat. Or is that an illusion?
J
File Type: zip
Old Aug 25, 2006 | 08:27 AM
  #33
Droid13's Avatar
J
I think it's just propped up a bit for a better picture.
Old Aug 25, 2006 | 08:46 AM
  #34
jbollt's Avatar
Originally Posted by WVGasGuy
This has always been the problem with EV vehicles. Where to put the batteries.
It would have been handy if the TCH had both seats fold with a more usable pass though area. ( Maybe even a hatchback opening?)
That's called a Highlander Hybrid (I know, V6 vs 4cyl)
Old Aug 25, 2006 | 09:20 AM
  #35
bruceha_2000's Avatar
The back seats don't fold? The Toyota site specs says 60/40 split folding rear seats: http://www.toyota.com/images/vehicle...y/features.pdf
Or maybe they don't fold flat forward? I didn't check that aspect of my friend's TCH. Being able to fold the rear seats is an absolute MUST for my wallet to open. Of course, I won't have that decision to make for some time as we hold our cars about 10 years
They do, they named it Prius :-)
Old Aug 25, 2006 | 09:34 AM
  #36
Orcrone's Avatar
It's a weird configuration. The TCH has the standard 60/40 folding configuration. However, the duct work for getting air to the battery is on the left side as looking through the trunk to the car. So even if you fold both seats down you only have a small section on the right side to pass things through.
Old Aug 25, 2006 | 09:41 AM
  #37
Droid13's Avatar
To be perfectly accurate, the whole small trunk issue on the TCH is not directly due to the battery. It's the ducting for the cooling system that is most inconvenient. If Toyota could figure out a better way to air cool the battery most of the complaints about trunk space would go away.
Old Aug 25, 2006 | 05:39 PM
  #38
tedpark's Avatar
Originally Posted by Droid13
...a better way to air cool the battery...
Doh! How 'bout some air intake scoops - like a jet or a Ferrari?
Old Aug 25, 2006 | 06:53 PM
  #39
AKM's Avatar
AKM
Somewhat hard driver
In an attempt to get this thread back on track............
If the Electric/Traction motor had about another 20-30hp and ability to operate in the 60mph range without feathering the accelerator like a granny (the current 40mph mode) this vehicle would be ideal.
Hopefully in the not to distant future (as battery technology becomes more involved) this will become a reality.
Old Aug 25, 2006 | 07:23 PM
  #40
Droid13's Avatar
When I first got my TCH I was a bit disappointed to see NiMH batteries as I had considered them obsolete compared with the power to weight of LiON.
After all the news about the Dell/Apple/Sony laptop battery recalls, I can fully understand now why Toyota is still using NiMH batteries instead of LiON. All it would take is 2 or 3 cars short circuiting into an inferno (think how close the battery and fuel tank are together) and the bad press will probably kill the whole hybrid concept (never mind the fact that regular cars catch fire and burn all the time). I imagine they will proceed very cautiously with new battery technology.
