Model number change on NAV?
Old May 22, 2008 | 02:04 PM
jpezz's Avatar
2009TCH w/NAV bought 4/08
Default Model number change on NAV?
I called a local stereo place and they said that since mid 2007, Toyota changed the NAV system and they weren't sure the backup camera would work with it. I pulled the vent and found the following numbers on the top of the NAV unit but I can't seem to find any info.
Can anyone interpret which is NAV model? (I believe top number is Toyota and bottom is Denso number)
Has anyone attached a camera to this model NAV?
86120-06460
DW468100-0336
Old May 22, 2008 | 10:25 PM
cngrevolution's Avatar
Default Re: Model number change on NAV?
well I have an 08 that is about 2 weeks old. I put the back up cam in no problem. I would have to pull my radio to check the numbers, but with an 09 you should be good. I installed mine in about 2 hours and it works like a charm!
Old May 23, 2008 | 07:09 AM
jpezz's Avatar
Thanks. Numbers are on top of the nav so the only thing that has to be removed is the vent unit.
Curated Content Editor
Tesla
Nov 4, 2013 11:00 AM
turbotaguy
Feb 25, 2010 09:30 PM
flounder
Mar 2, 2008 11:59 AM
spiffnme
Mar 25, 2007 11:13 PM
dalerb
Sep 27, 2006 08:46 AM
