Which Mode was I in
Old Aug 6, 2007 | 04:37 PM
alan_in_tempe's Avatar
Veracitorian Muser
Default Re: Which Mode was I in
Originally Posted by FastMover
Huh?
Typo! Sorry. That was supposed to be "MG2/wheels". MG2 and the wheels (differential) are geared together; their combined torque are what get applied to the planetary set with the ICE and MG1 being the other two inputs to the planetary gearset. (MG2 also turns through a second set of planetary gears, but that is a direct gear reduction, and not a three way power split as in the primary planetary gearset referred to as the Power Split Device.)
-- Alan
Old Aug 6, 2007 | 04:42 PM
FastMover's Avatar
Old Boomer Techie
Thumbs up Re: Which Mode was I in
Better!
Old Aug 7, 2007 | 09:42 AM
SPL's Avatar
SPL
rburt07 — Your new data correspond (according to my calculations) to "heretical" mode operation with MG1 acting as a motor at a speed of -1492 rpm. Your fuel consumption of 0.7 galUS/h = 2.65 L/h corresponds to FE of 3.3 L/100 km = 71 mpgUS. This is in much better agreement with your SG measured result of 67 mpgUS. Perhaps the non-use of air conditioning (whose electricity usage has to be made up by consuming fuel) made the difference. Or else, last time you may have been burning some fuel to top up the NiMH battery or 12-V battery. My calculations assumed that all electricity generated was being shuttled as electrical power between the MGs — it's close to the steady-state situation, and the only case that I can analyze. I'm also assuming 100% efficiency in the MGs — reality seems to be around the 95% mark for each, from both my experience and from what I've read.
The attached excerpts might help explain how heretical mode can improve engine efficiency by (in most cases) forcing down the ICE's speed while increasing its load, to produce the required power at the greatest possible efficiency. They are taken from Toyota's US patent #6 131 680, posted earlier by me in the thread "Heretical Mode." Fig.12 shows as dotted lines C1-C3 the constant-power curves of an ICE. They are hyperbolas since (ICE torque Te) x (ICE rpm Ne) = (ICE power Pe). At any required engine power, one can in principle run the engine at any point along the dotted curve corresponding to the needed ICE power (e.g., for cruising at the given speed). The closed curves labelled with engine efficiency numbers a% represent combinations of engine torque and rpm at which it has the same thermodynamic efficiency. The ICE's highest possible efficiency occurs at point A1 on power curve C1. If that's the power you need, then the ICE should be operated at the torque/speed combination represented by point A1. Usually, you need less power than this, say a power represented by curve C3. Then point A3 is the point on C3 corresponding to the greatest efficiency possible at that power. Curve A is the engine's "maximum efficiency operating curve," and is stored in a lookup table in the ECU. For each power requirement, the ECU determines where best to operate the engine. Curve B is the boundary of the operable range of the engine. Fig.13 plots how the efficiency varies with engine rpm as one moves along each of the curves C1, C2, and C3. The peak efficiencies occur at points A1, A2, and A3 respectively. This is explained in more detail in column 25, lines 26-58 in the patent.
The point is that, at power requirements less than C1, it's most efficient to force the engine speed Ne down and its torque Te up. This is what is happening in heretical mode. End of lesson!
alan_in_tempe — What you're saying is not really in conflict with what I'm saying, although I do disagree with some of your specific statements. I am relying on basic mechanics to draw physical conclusions about energy flow. They are independent of the precise electrical mechanisms used to drive the MGs in order to achieve this end. You are right about how the MGs must be driven, but this is immaterial to my argument. What I'm saying must be true if physics is to remain valid here. Let me elaborate.
First, there must be a balance of torques at each shaft 'S', 'C', and 'R' in the nomograms; for example, the torque exerted by the engine on MG1 must (by Newton's third law) be equal and opposite to the torque exerted by MG1 on the engine. Since the planetary-gear's "torque-split" is always 72% to the ring-gear (MG2) and 28% to the sun-gear (MG1), the ICE's torque Te always splits this way. This split is shown by vectors Tes and Ter in my diagrams. The torque Tm1 always opposes Tes to provide balance at shaft 'S'. The torque Tm2 can either reinforce or oppose Ter depending on the operating mode. And the wheel torque Tr combines with Ter and Tm2 to provide balance at shaft 'R'. It is not necessary to consider shaft 'C' any further in this analysis, but if you like, you can add the needed vectors to see that there's balance there too.
Let me address a couple of your specific claims:
  • No, both MG1's and the ICE's torques cannot be negative at the same time, for then balance wouldn't hold at shaft 'S'.
  • If, for example, the product (torque Tm1) x (rpm Ns) is positive, then power is flowing into MG1, and so it is acting as a motor. If Tm1 x Ns is negative, then power is flowing out of MG1, and so it is acting as a generator. This is true irrespective of any considerations about MG1's drive voltage. Yes, the voltage must be chosen correctly in order to achieve the desired torque Tm1, and this is the function of the ECU, but the voltage per se is irrelevant to my physical argument.
  • The MGs are rated at up to 650 Vac, and MG2 is rated at 105 kW, although the combined (engine + battery) power sent to it can't reach this figure.
Stan
File Type: zip
Old Aug 7, 2007 | 10:10 AM
FastMover's Avatar
Old Boomer Techie
Post Re: Which Mode was I in
Originally Posted by SPL
....The point is that, at power requirements less than C1, it's most efficient to force the engine speed Ne down and its torque Te up. This is what is happening in heretical mode. End of lesson!
Exactly! The thing I have been exploring on the other thread that Stan mentioned deals with how to best convince the ECU that power demand has dropped sufficiently to cause this event.
I have not seen anyone with a metric car talk about this yet, but in the US car, at the speeds you mention, and in this mode, I have been attempting to discover why the power indication (battery to wheel on the center display) remains on for quite extented periods of four or five minutes, with the ICE providing most of the power in the 40-59.9 MPG range. I agree with Stan that, therotically at least, this should eventually discharge the battery. However, that does not seem to be the case. It may be that the power being delivered by the battery is very low, or that somehow MG2 is charging the battery at the same time. I don't know why or how yet, but I do know that I have been able to maintain this condition for up to 10 minutes on a flat stretch of road during my morning commute.
2008 Honda CIvic Hybrid
Mar 1, 2008 09:16 AM
BIF
16
May 8, 2004 05:51 PM
Jumperless
Off Topic
48
Mar 4, 2004 05:05 PM
