Is it me... or the wiring?
Old May 17, 2008 | 04:12 PM
UWAdventurer's Avatar
Default Is it me... or the wiring?
I'm looking for a 12 volt wire under the dash to make the switch in a relay. Low current draw. I want a wire that shuts off with the ignition. I'm not having any luck finding a suitable wire. Can someone help? If you can, can you advise the color and location?
Old May 17, 2008 | 04:50 PM
nyceshirtz's Avatar
Default Re: Is it me... or the wiring?
i cant help you with color, but if you look in the back of the storage compartment with the "garage door type cover" behind the shifter console there is a cigarette lighter adapter in the back left. this adapter is only on when the ignition is on. you can tap into that wire if you want!
Old May 18, 2008 | 09:41 AM
Thanks, I had checked that before and though it was hot all the time but checked it again and you are right. Thanks.
Old May 18, 2008 | 09:53 AM
cngrevolution's Avatar
UWA, was wondering what "hybrid" tint is? I saw it in your mod list and was curious. thanks!
Old May 18, 2008 | 11:22 AM
Mystifier's Avatar
I have a sub amp under my passenger seat and I used that wire for the remote turn-on lead. Works great! And isn't it nice how easy the center console pieces just pop right out? Made that job a snap!
Old May 19, 2008 | 03:43 PM
Hybrid window tint has some metallic elements to it but is not a full metallic tint.
PflHybrid
Toyota Highlander Hybrid
16
Jul 12, 2007 07:35 PM
HoslerD
Oct 14, 2006 04:37 AM
raypou
Jun 23, 2005 09:00 PM
hiram6
Jun 21, 2005 06:03 PM
curmudg
Apr 14, 2005 05:45 PM
