Maint Req'd warning at 24,500 miles
Old Nov 2, 2009 | 05:17 AM
haroldo's Avatar
Default MAINT REQD warning at 24,500 miles
I use trip set A for oil change intervals.
At 4950 miles the MAINT REQD warning came on 'briefly' (cycling through clears the warning) which I believe is correct, since it gives you 50 miles before your next oil change as a warning.
After 5000 miles, the warning stays 'solid' (you can cycle through to see the other information, but the warning returns after five seconds).
I'm okay with that.
This morning the warning came on and stayed solid (cycling throught didn't clear it).
I looked at my odometer reading and noticed that the car hit exactly 24,500 miles when the warning went solid.
Trip A (oil reset) was at 4987.
I thought the warning was only for oil changes and came on only when the miles hit 5000.
Is there anything that would cause this?
It seems like it's more than coincidence that it went solid at 24,500
It's not a big deal as I reset the indicator in anticipation of a scheduled oil change, however occurring at this mileage interval is a little troubling.
According to Toyota.com...
2008 Camry Hybrid
25,000 Miles - 30 Months
Replace engine oil and oil filter 1
Rotate tires
Visually inspect brake linings/drums and brake pads/discs
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Tighten nuts and bolts on chassis and body
Driving on Dirt Roads or Dusty Roads
Inspect ball joints and dust covers
Inspect drive shaft boots
Inspect engine air filter
Inspect steering linkage and boots
Applicable Footnotes:
1) Reset the oil replacement reminder light ("MAINT REQD") or the message "OIL MAINTENANCE REQUIRED" on the multi-information display after engine oil replacement.
Any ideas?
Old Nov 2, 2009 | 07:08 AM
haroldo's Avatar
Default Re: Maint Req'd warning at 24,500 miles
I called the dealer...there warning only comes up for the 5000 interval of the last reset.
bizarre...unless dealer never reset the warning last time and it was 5000 since I had reset it prior to the last oil change
Old Nov 2, 2009 | 12:23 PM
Mendel Leisk's Avatar
Just to summarize: Is your car telling you to change oil after around 4500 miles instead of the usual 5000? Maybe there's more to it than straight mileage count, ie: engine temp, trip duration, etc. Either way I wouldn't lose any sleep over it.
Old Nov 2, 2009 | 01:24 PM
jbollt's Avatar
My exprience in over 60,000 miles on my '07 TCH is thet the reminder begins to "stay on" at 5000 miles after it was last reset. I have had mine come on while on a trip, and have reset it so the rest of the info is available on the MID...knowing that I would have the oil changed when I return home. It is easy to reset it. Maybe your last oil change (and reset) was at 19,500??
Also of note, resetting the reminder resets Trip A to 000.
Old Nov 2, 2009 | 01:54 PM
haroldo's Avatar
I guess it must have been reset at the exact figure.
Old Nov 2, 2009 | 07:14 PM
alphabetbackward's Avatar
It was my understanding that the light would turn on at 4,500 miles since the last reset but turn off after a few seconds. At 5,000, it stays on until you reset it.
Old Nov 2, 2009 | 10:10 PM
rburt07's Avatar
My warning comes on about 450 miles before it needs changing. The maintenance bug don't come on other then when I first start the car. I do know the bug or tag will become more annoying as it gets closer to time to change the oil and filter. I got so upset at it last time I decided to change the oil and filter early. It just started showing up again so i may do the same again as it would be right at 5000 miles from the last change.
Old Nov 3, 2009 | 01:22 AM
haroldo's Avatar
you're probably right, I think I was wrong saying that it was a 50 (rather than 500) mile 'heads up'
zookarama
Jun 23, 2009 07:30 PM
tecis
Aug 17, 2007 12:05 PM
zimbop
Mar 4, 2007 07:20 AM
stevenvillatoro
Nov 25, 2006 09:53 PM
hiram6
Apr 23, 2005 02:50 PM
