low tire pressure warning
Old Sep 21, 2006 | 11:02 PM
dakid13's Avatar
Default low tire pressure warning
I keep my cars tire pressure at about 45 psi and I was wondering how I could raise the low pressure warning to 45 psi instead of below 32 psi. Does the dealership have to do this for me or is it something I could do myself? I'd appreciate any help, thanks.
Old Sep 22, 2006 | 12:27 AM
JHSmith's Avatar
Default Re: low tire pressure warning
The alarm pressure point can be set by you.
After setting the tire pressure to the point you wish, in the glove compartment on the extreme left side, you should see a small switch on the mounting frame. This is the Tire Pressure Reset Switch.
Here are the instructions from the Service Manual: (I don't have the OWNER's MANUAL with me right now.)
4. TIRE PRESSURE WARNING RESET SWITCH
• By operating the tire pressure warning reset switch,
the tire pressure warning ECU can be set to issue a
warning at an inflation pressure that corresponds to
the type of tires.
• Operate the tire pressure warning reset switch only
after the inflation pressures of all tires have been a
djusted on the vehicle.
• To initialize the system, press and hold the tire
pressure warning reset switch for 3 seconds or longer
with the ignition switch on (IG). After the initialization
process has started, the warning light blinks 3 times
(1 second on, 1 second off).
• During initialization, the tire pressure warning valve
and transmitter measures the inflation pressure of the
tires, and registers the signals that are transmitted
into the tire pressure warning ECU at a frequency of
once per minute. The initialization process is
completed when signals from the all tires have been
received.
I have only recently received my TCH, so I cannot verify this information.
I hope this helps.
Old Sep 22, 2006 | 05:40 AM
schmidtj's Avatar
Keeping Toyota Solvent
Originally Posted by dakid13
I keep my cars tire pressure at about 45 psi ...
Is it true that now if you run over a dime you can tell if it's heads or tails?
Old Sep 22, 2006 | 06:13 AM
AKM's Avatar
AKM
Somewhat hard driver
LOL, when I was browsing this site the other day I noticed a poster who said he is running 50 pounds!
Tire pressures are treated like MPG on this site, the bigger the numbers the better.
Old Sep 22, 2006 | 06:19 AM
schmidtj's Avatar
Auto manufacturers got away from solid tires back in the teens. Maybe some people don't realize that?
Old Sep 22, 2006 | 10:32 AM
flopshot's Avatar
Did you know that if you are on the internet, you always have the owners manual with you?
http://www.toyotaiguide.com/content/07Camry/iGuide.htm
Old Sep 23, 2006 | 12:50 AM
JHSmith's Avatar
Thanks for the info concerning iguide.
I knew about it (I even have it bookmarked), but unfortunately, I couldn't open the page.
My TCH was being used by others and I normally keep the Owner's Guide in the car (unless I want to do some "light" reading)
Old Sep 23, 2006 | 07:00 PM
AKM's Avatar
AKM
By the looks of it, Toyota should offer a high tire pressure warning as well! LOL
Old Sep 23, 2006 | 08:36 PM
stevenvillatoro's Avatar
Arrow Re: low tire pressure warning
Or psychological counseling for those who become traumatized by a few extra pounds!
Old Sep 24, 2006 | 09:13 AM
Rcommander's Avatar
Advanced Technology-PZEV
lol i hope there was no pun intended!
jimmy1
Feb 4, 2012 03:41 PM
maloski
Aug 20, 2009 09:42 AM
Oiler
Jul 19, 2007 06:50 AM
sirfergy
Nov 29, 2006 11:11 AM
jocular_chen
Sep 27, 2006 09:57 AM
