Which light bulb is the daytime running light?
Old Jan 4, 2016 | 05:06 AM
haroldo's Avatar
Default Which light bulb is the daytime running light?
2008 Camry
I need to replace my daytime running light bulb. I don't see it specifically listed in the manual. Is it the headlight low beam?? (it shouldn't, since those lights work, it's only one of the DRLs that is out)
Thanks!
Old Mar 2, 2016 | 07:36 AM
RemyMartin's Avatar
Default Re: Which light bulb is the daytime running light?
The DRL's are the Highbeam in low power. The only reason I know is because I am trying to add more lighting to it and I was looking to use the DRL's but I cannot.
Old Mar 3, 2016 | 02:24 PM
litespeed's Avatar
Professor Emeritus
I replaced all of mine recently. I pulled one just for fun and it was all black and melted. So, I pulled the rest of them and they all looked disfigured and the High Beams were black. They all still worked, just looked bad, so I replaced them. Much better now.
Old Mar 7, 2016 | 09:45 AM
haroldo's Avatar
Thanks!
Make sure you don't touch them...the oils from your fingers can end up frying the bulb (or so I've heard)
Old Feb 20, 2017 | 11:09 PM
Mickey_D's Avatar
The bulb is an H11 halogen bulb. And no, you cannot replace them with LED because the bulbs pull dual duty as high beam and DRL. LED's would just go full high beam no matter what.
Old Feb 21, 2017 | 05:15 PM
ukrkoz's Avatar
Yeah you can
http://www.ledheadlightspro.com/9007...SIoaAoJG8P8HAQ
Amazon Amazon
Old Mar 4, 2017 | 03:15 PM
Mickey_D's Avatar
Not on my 2008 Hybrid you cannot. THe DRL/High Beam is a single element bulb that is supplied a lower voltage for DRL use. Put in a single element LED (which goes to full brightness at 10V) and your DRL and high beam will be equal brightness, blinding the heck out of everyone you approach.
The bulb you linked to is a 9007 type dual element bulb used in single bulb applications, which our TCH are not.
Old Mar 5, 2017 | 06:33 AM
ukrkoz's Avatar
Yeah but it shows that there are dual brightness LEDs. Right?
haroldo
Apr 6, 2012 05:35 AM
rysa4
Dec 2, 2008 05:58 PM
bg1811
Dec 22, 2006 02:24 PM
dpmitche
Aug 25, 2006 11:31 AM
sweetbeet
Nov 10, 2005 03:06 AM
