Which bulb is the daytime running light?
Old Apr 4, 2012 | 06:50 AM
haroldo's Avatar
Default Which bulb is the daytime running light?
My DRL bulb is out and I'm looking at the manual and it lists
  • Front side marker lights
  • Front turn signal/parking lights
  • ...and then a few rear lights
Which bulb is it?
Old Apr 4, 2012 | 08:08 AM
alan_in_tempe's Avatar
Veracitorian Muser
Default Re: Which bulb is the daytime running light?
I vaguely recall that it is the high-beam headlight at half power. However, I am pretty sure it is either the high or low beam, which I believe are both in the same bulb. If you turn on your low beams and see one (or both) out, you have the answer. If not, turn on the high beams and look for one of them out.
Another option would be to wait a few minutes when it is likely that someone with the exact answer will reply.
-- Alan
Old Apr 4, 2012 | 09:06 AM
wwest's Avatar
Most commonly Toyota runs the 2 high beam bulbs in series to get 6 volts each, one bulb fails, no DRLs. High beam mode gives greater viewable range.
Old Apr 4, 2012 | 10:36 AM
lincolnshibuya's Avatar
they call it headlight bulb 1 and bulb 2. The DRL is bulb 1. I think they are the same bulb spec.
Old Apr 4, 2012 | 10:52 AM
haroldo's Avatar
thanks! (I hate the headlight bulbs...too expensive!)
Old Apr 4, 2012 | 06:38 PM
SteveHansen's Avatar
Pragmatist
It is generally a good idea to test ALL of the bulbs on a car, occasionally, and replace any that don't work. That used to be part of an oil-change interval service.
Every day, I see cars on the road with one or two of the three brake lights burned out. I am sure there are some that have all three brake lights burned out, but those are harder to tell.
Old Apr 6, 2012 | 05:35 AM
rburt07's Avatar
Make sure the parking lights work. Turn them on, is one notch below where it says, headlights. I'm not sure, but I thought the running lights were amber and also bright during the day. The DRL's could be the parking lights, sure worth a look.
rysa4
Dec 2, 2008 05:58 PM
mikesus
Feb 4, 2007 11:47 PM
bg1811
Dec 22, 2006 02:24 PM
dpmitche
Aug 25, 2006 11:31 AM
sweetbeet
Nov 10, 2005 03:06 AM
