Lets talk about Toyota DVD Navigation
Old Jun 23, 2006 | 09:13 AM
WVGasGuy
Guest
Posts: n/a
Default Re: Lets talk about Toyota DVD Navigation
07TCH, I fought with that "woman" over half the way to Nags Head last week. I had to get beyond the half way mark before she finally rerouted me the direction I wanted to go.
I have not figured this out yet but I did see other posts where I guess it may give 2 alternate routes and you select. I might have had that option and just didn't select it. Even though I am an engineer, these electronic things confuse me, and until someone shows me how to use it I'll probably not figure it out completely. I'm not doing well with the written manual.
Old Jul 16, 2006 | 05:41 PM
ibdave's Avatar
I'm wondering if I can use my dvd Inav 3.0 disk in the Camry. I have the Inav 3.0 for my pda/gps. I wondering if anyone else has tried it yet with any other software..
Old Jul 16, 2006 | 06:14 PM
spiff72's Avatar
Nope. I think it is safe to say that you have to use the OEM DVD's in the system.
Old Mar 9, 2007 | 11:42 AM
wilsons66604's Avatar
Led-footed HyBrid geek
I'm new to this nav system and am wondering if I'm missing something.
Everytime I've entered a destination, I get 3 routes....ALL THE SAME! (and wrong as well)
The system never takes the most direct route. It always chooses a route that has the busiest streets.
Is there any way of tweaking these options?
Old Mar 9, 2007 | 01:10 PM
Geckoboy's Avatar
One thing I did which I dont see mentioned in this thread is to set the speeds for the type of road (freeway, main, side or something like that). It looks like it's used to compute the arrival time, which leads me to believe that it takes those speeds into account when searching for routes.
I believe the defaults were 55, 35, 25 for freeway, main roads, and smaller roads. I would suggest you guys set those speeds appropriately and then see if the system gives you a better route based on those numbers.
Old Mar 9, 2007 | 01:13 PM
Geckoboy's Avatar
Are the ETA on those routes the same? I noticed that although the routes looks the same, the ETA's are different, with arrival times earlier or later. It seems to me that since it zooms the map to show the entire route, you can't tell on the street level if it uses a different street or not. I'd bet that the differences between routes that looks the same are very minimal, like turning left instead of right on a block which makes you go around it, adding 2 more minutes to your commute.
Old Mar 9, 2007 | 01:37 PM
  #27
spiff72's Avatar
About how long is the route you are calculating? If it is very short, many times there is little difference between them. The longer the trip, the more variation there can be.
Old Mar 9, 2007 | 01:54 PM
  #28
The routes I'm refering to are very short and do not differ at all.
I have not compared the ETAs.
I'm spoiled by my TomTom device. It used all roads and did not try to stay on just the main roads as the TCH seems to be doing.
(I have also set my speeds)
Old Mar 9, 2007 | 07:52 PM
  #29
JTode's Avatar
Originally Posted by stevenvillatoro
I'm really happy with the stereo... it was an unexpected surprise. Got a 1' cable from Radio Shack, and routed it through the secret holes in the center comparment to the cubby holes flanking the center console... it's the perfect iPod holder.
That sounds interesting... where are those secret holes? I've got a pretty good rapport with the service manager at my dealer, maybe I can get him to route that, and maybe wire up a charger for me as well.
I've also been debating getting the nav installed, but it's pretty pricey up here, particularly when I can get an aftermarket one to use on trips for about 1/6 the price. Does it play DVDs as well, by chance?
Old Mar 10, 2007 | 03:25 AM
  #30
Toyota provided a knockout plug on the passenger side of the forward console compartment in all 07 Camrys. The same compartment that has the AUX and power plug. Just pop the plug out with your finger and you can route the AUX cable thru there.
The factory Nav system does not play DVDs
Curated Content Editor
Aug 5, 2014 05:01 AM
Jay_Taipei
Lexus RX 400h
Jun 16, 2006 11:00 PM
philmcneal
Off Topic
Feb 15, 2006 01:14 AM
9G-Man
Dec 2, 2005 09:06 PM
Jason
Hybrid & Related News
Sep 25, 2004 03:32 PM
