MPG Calculator Problem?
Old Mar 9, 2007 | 06:47 PM
TCH Newby's Avatar
Unhappy MPG Calculator Problem?
I've been watching the tank average MPG calculator from time to time, and it had looked pretty consistent. It changes radically when I first gas up, but starts to stablize (not change radically) within a few miles. But last night, with about a little less than 1/2 tank left, I stopped to pick up some dinner. When I started the car again about 20 minutes later, I noticed the Tank Average number started to change radically, jumping all over the place to the point I don't trust the reading it's giving, and it hasn't corrected itself yet.
Has anyone had this happen before? With this many electronics in this hybrid, I wonder if there's a button that keeps "resetting" the tank average calculator constantly that should only be "reset" when I gas up.
Thanks for your help.
Old Mar 10, 2007 | 09:49 AM
tnsig's Avatar
Default Re: MPG Calculator Problem?
I believe the tank average on the MFD resets itself when the fuel door is opened. You may try opening the fuel door to "reset" it and see if that works. I only use the tank average in the car to get an idea of what I'm getting. I've developed a spreadsheet that I populate every time I refuel to get actual MPG readings.
nicst47
Jan 18, 2008 08:21 AM
Sporkman
Off Topic
Jan 14, 2008 02:35 PM
cjbts
Jun 27, 2007 12:31 PM
Eskrimast1
Aug 16, 2005 02:12 PM
