Jump Starting
Old Sep 19, 2007 | 02:25 PM
Paulgw's Avatar
Default Re: Jump Starting
I have just searched and found in the owners manual the attached description of how to jumpstart a TCH. It still does not seem very clear as to whether the TCH will start immediately the booster battery is connected or whether I have to wait around until it has time to charge up the 12v battery. It also seems that all the precautions described to prevent the booster battery exploding would be more applicable to starting a regular car which would require a much higher amp draw and I have never heard that it was necessary to take such precautions.
File Type: doc
Old Sep 20, 2007 | 06:02 AM
ag4ever's Avatar
Dazed and Confused
You don't have to wait.
The small battery in the trunk is only used to power up the computer systems. it is not used for "starting" the car. The traction batteries do all the real work of starting the engine when needed and powering the motor/generators.
So in theory, a small pack of AA batteries that are put in series to give 12 volts should be enough to start the car. Once the computers are booted the traction battery "back feeds" the small battery and it will then have enough voltage to power the computers without the AA pack.
Old Sep 20, 2007 | 06:10 AM
Paulgw's Avatar
Okay thanks for the reassurance so here's my next question. Can the HV battery in an emergency be recharged by anybody other than a Toyota hybrid service centre? The reason for my question is that I will be driving my TCH in Mexico shortly, (that's a definite!).
Toyota sell and service regular vehicles in Mexico but not hybrid cars. Honda however do sell and service the the Civic Hybrid so I am wondering if special Toyota equipment is needed or Honda could recharge the TCH HV battery.
I believe it is extremely unlikely that I will have this problem but would like to go armed with as much information as possible just in case.
Old Sep 20, 2007 | 01:48 PM
n8kwx's Avatar
1 - if you discharge the traction battery, you've got other problems. It is well protected against discharge. In normal use you can't kill it. Leaving the lights on won't do it.
2 - The answer on charging is no. Only the dealers have access to the HV chargers. And they don't even have them in stock. I've heard they fly a guy around with a charger. They evidently don't trust the charger and/or the mechanics. If you know what you are doing around HV DC, people have built chargers and charged batteries on their own.
3 - Go drink a few margaritas and don't worry... You can jump the 12 volt battery easily with any car (OK, perhaps not a model T) and the HV battery won't need charging.
Old Sep 20, 2007 | 10:57 PM
Paulgw's Avatar
Gracius Marc y salud. I feel better even before the margarita!
Paul
Old Nov 21, 2007 | 06:30 AM
pjp's Avatar
pjp
I left the rear dome lights on while cleaning and treating the leather this past Sunday afternoon. When I saw the car again, about 40 hours later, the battery was dead. I agree with the prior posts expressing surprise that there is no built-in battery protection for such mistakes on the car, but ultimately that's my fault.
The reason for my post, though, is just to laugh about the look on the AAA guy's face when I started the engine. I hopped out of the car to thank him and tell him it was running before the ICE fired up. He was utterly amazed that the car was running and not making a single sound. Quite funny, really. I figured he would have jumped a hybrid by now, but I guess not.
Happy Thanksgiving, everyone.
Old Aug 25, 2009 | 02:47 PM
SteveHansen's Avatar
Pragmatist
Originally Posted by chris_h
I have a truck that I only drive a few times a year and have to jump every time. I have used the TCH to jump it at least 3 times, and I did not wait 15 minutes for the truck battery to charge. I usually just wait about 2 minutes.
I have a similar truck -- drive it once or twice a month. It has an alarm system that will drain a battery in just a few days. I got tired of jumping the thing. So I got one of those little tiny trickle chargers, and ran the DC leads from the battery into the cab of the truck. (The cigarette lighters on that truck are disconnected when the truck is turned off.) An AC extension cord runs from the house to the cab of the truck. I just have to make sure I unplug it before I start the motor and drive away.
Old Aug 25, 2009 | 10:27 PM
n8kwx's Avatar
Steve,
There are some solar panels marketed as battery maintainers. This could give you a "wireless" solution.
Or simply disconnect the alarm - get a trunk monkey instead. (search YouTube for "trunk monkey" - an absolutely hilarious set of commercials).
Old Dec 27, 2012 | 11:32 AM
ke4harper's Avatar
Maybe someone can confirm the hint given below as a required step to jumpstart a TCH? Just went through this; left my car (2008 TCH) at the airport for a week with a rear dome light on. On return the only access to the car was with the manual key, not enough power in the 12V battery to even open the door. A police cruiser was generous enough to follow the instruction manual guidance with me: connect jumper cables and charge for about 5 minutes, then start the TCH. No joy even after 20 minutes of connect time. Went back with another car late yesterday evening and was able to get the TCH started a couple of times but no restart on its own because the 12V battery is toast. Now today a AAA technician shares a secret: the TCH computer has a safety "feature" where you must have the key out of range when connecting the jumper cables, and then bring the key back in range to start the car. It worked flawlessly. What do you think?
Old Dec 27, 2012 | 12:14 PM
Ron AKA's Avatar
Have not heard the trick about keeping the key out of range. However I found these two notes in the 2012 manual:
"The hybrid system may not start on the first attempt after the 12-volt battery
has recharged but will start normally after the second attempt. This is
not a malfunction.
The “POWER” switch mode is memorized by the vehicle. When the 12-
volt battery is reconnected, the system will return to the mode it was in
before the 12-volt battery was discharged. Before disconnecting the 12-
volt battery, turn the “POWER” switch off.
If you are unsure what mode the “POWER” switch was in before the 12-
volt battery discharged, be especially careful when reconnecting the 12-
volt battery."
pakirk
Saturn Vue Green Line
Sep 26, 2013 07:14 AM
Longhorn
Jul 18, 2011 04:31 PM
hertfordnc
Sep 20, 2010 12:09 PM
Jason
Hybrid & Related News
Apr 2, 2005 05:37 PM
Jason
Website Questions & Input
Mar 27, 2005 07:34 PM
