Info if you have had your Camry Hybrid windshield replaced
Old Jul 6, 2007 | 07:34 AM
  #31
ag4ever's Avatar
Dazed and Confused
Default Re: Info if you have had your Camry Hybrid windshield replaced
I believe all windshield glass in the US is laminated. That way, if you are in an accident and your face was to hit the windshield, it would not be severly cut. The plastic film on the inside would be a barrier between you and the glass that is breaking. And to be even more specific, the laminated glass is also tempered so it will shatter in small pieces and not large shards that can cut thru the plastic lamination.
Old Jul 6, 2007 | 10:17 AM
  #32
chestr's Avatar
Okay--
Laminated glass consists of two layers of annealed glass bonded together by a tough, pliable and invisible layer of polyvinylbutyral (PVB). This type of glass construction offers important safety & other benefits in automotive applications:
· Objects striking the glass are much less likely to penetrate and enter the vehicle cabin. Laminated glass provides enhanced barrier qualities to outside object intrusion.
· In the event of an accident, laminated glass assists in maintaining the occupants within the vehicle's safer environment.
· In the event of glass breakage, the damage is normally confined to a localized area, thereby preserving visibility in other parts of the window.
· Should glass breakage occur, broken pieces tend to remain intact, even in the area of impact, adhered to the PVB interlayer. This quality of laminated glass protects vehicle occupants by retaining broken glass fragments.
· Made with highly weather-resistant materials, LAMISAFE brand products are virtually unaffected by harmful UV rays and severe temperature variation. They offer clear visibility even after many years of service.
Tempered glass is created by heating annealed float glass to near melting point, rapidly cooling its surface and allowing the inner core to cool naturally. The glass is cut to size prior to heating, shaping and quenching.
Tempered glass is at least five times stronger than ordinary flat glass resisting impact, shock, thermal and mechanical stress. It also can flex more without breaking. Tempered glass is well suited for automotive applications due to its unique fracture characteristic. If broken, it fragments into small and less harmful pieces providing a safer environment in case of accidents.
Looks like the windshield is laminated, the other windows are tempered. So at that point I have no clue what the identifiers might be for acoustic-dampening glass vs non.
Old Jul 7, 2007 | 04:18 AM
  #33
rscott's Avatar
An Enthusiast
Originally Posted by chestr
Laminated glass consists of two layers of annealed glass bonded together by a tough, pliable and invisible layer of polyvinylbutyral (PVB)....
Excellent work on the benefits of laminated glass! :)
I believe that the only way is to [1] check the DOT and M numbers on the windshield markings, and either [2a] compare them to known numbers for acoustic-dampening glass (e.g. DOT20 M3K4, which many/all of the Camry Hybrids use), or [2b] contact the manufacturer and see if they let you know. I'm probably going to be contacting some glass manufacturers to get some of that information on www.carwindshields.info, but I'm not sure if the glass manufacturers will want to share that information.
Every windshield that has the same DOT and M numbers should have the same acoustic qualities.
-Scott
Old Aug 28, 2007 | 04:34 PM
  #34
li6am's Avatar
I can't believe it. I found this website today, and I just replaced my TCH windshield last week for $420. After reading your post, I went out and sure enough it's a DOT376.
I guess I need to call the windshield company, and try and get it figured out.
Sounds like this may not bee too easy!!!
Thanks for all the information!!
Old Aug 29, 2007 | 05:38 AM
  #35
rmorrow's Avatar
DOT376 simply means that the windshield is made by AP technoglass Corp which is the American subsidiary of Asahi Glass Co in Japan (which is indicated by DOT20).
American-made Camry Hybrids come with the DOT376 M834 markings. This glass is presumabaly identical to that used in the Japanese-made Camrys, with the DOT20 M8K4 markings.
See this thread https://www.greenhybrid.com/discuss/...houghts-14335/ for more details.
Last edited by rmorrow; Aug 29, 2007 at 05:40 AM. Reason: Included link to other thread
Old Sep 1, 2007 | 10:42 AM
  #36
vortexkp99's Avatar
Exclamation Re: Info if you have had your Camry Hybrid windshield replaced
Our TCH windshield got a smaller than a pencil tip rock chip in the driver side support beam area about 3/4 the way up from the bottom not visible from the driver at 1557 miles. Less than a week later it spidered out spreading through more than half way across. I have $0 deductible and asked for OEM glass. Safelite was the company the renewed the glass. The total bill came to under $300 to insurance. When I called the Toyota dealership for part info, the parts manager looked it up and a new windshield was about $1200.
After rechecking my glass it was marked: Toyota, Lamisafe, 4 AP Tech, M-834 AS1, DOT-376.
Other glass on the car was marked Temperlite.
Old Sep 4, 2008 | 01:08 PM
  #37
Fooshe's Avatar
I got in my car today and I just found a crack starting from the pass side A-pillar and it is csowing going to the driver's side. I did not hit anything and park in a garage at both home and work...What is even better is the quote the So Cal Toyota dealer just gave me; $1,200! claim is being filed with insurance today. I will let you know what the glass says once they replace it.
This is bull$#!%.
Old Jul 11, 2009 | 03:20 PM
  #38
Joe.B's Avatar
I just had my Camry Hybrid 2007 front windshield replaced due to a rapidly spreading crack that started in a rock chip. Safelite AUto Glass in Metarie, LA did it for a total cost of $337.07 (incl. glass 249.95, labor 60.00, taxes 27.12).
The new window corner markings are: "ACG Automotive DOT-376 M834 AS1 30E Lamisafe." The original window markings also said Lamisafe. The Safelite receipt said "replace with new 820213 - W/Shield Electrochromic Mirror~Solar~Acoustic Interlayer~W/Third Visor Frit Part#FW02719 6BYNMF"
From lists on the internet:
DOT376 AP TECHNOGLASS CORP BELLEFONTAINE, OH, USA
AS1 is the clearest glass (at least 70% light transmission), is laminated, and can be used anywhere in a motor vehicle (typically just the windshield)
[http://www.carwindshields.info/windshieldmarkings.htm]
Lamisafe is a trademark name, see details at http://www.autocentral.com/product.m...ety-Glass-0001
Looks good to me - I can't tell the difference from the original in the short drive home.
Joe
Old Jul 14, 2009 | 10:16 AM
  #39
picasa99's Avatar
My Windshield currently has a Toyota Lamisafe ASAHI M8K4 ASI DOT20 on it. But it has a big crack on it and was scheduled to be replaced today by SafeLite but he got the wrong kind of Glass since my Camry Hybrid has the automatic rear view mirror. Supposedly there is a black strip on the center of the mirror where the rear view mirror stick to hide the wires.
The Glass that the technician had got was a PILKINGTON - SOLAR ASI DOT 177 M20 (FW 2718) which is without the black strip. He is now going to get an FW 2719 which specifically has the black strip in the center. The glass did have a logo (picture) on it which resembled like a Noise Barrier which probably tells that the glass is Acoustic. This is a after market Windshield and not an OEM one.
Hope this information helps !!!
Old Jul 14, 2009 | 11:14 AM
  #40
Joe.B's Avatar
picasa99,
My original windshield had the identical markings, but the ASI is actually AS1. From other postings the DOT20 is the glass factory in Japan, and I suspect you must have a Japan built Camry Hybrid as I do. The ones made in the US got their glass from a US plant DOT376, as per previous postings on this as I recall.
I have the same automatic rear view mirror, and when I first called the Safelite national number, they asked me a series of questions to identify the right glass part: 2007...Toyota...Camry...Hybrid...auto mirror? Sounds like the person who first ordered the glass for you forgot the last question.
Joe
