Info if you have had your Camry Hybrid windshield replaced
Old Jun 28, 2007 | 04:15 AM
rscott's Avatar
An Enthusiast
Default Re: Info if you have had your Camry Hybrid windshield replaced
Originally Posted by ag4ever
How does the noise reduction rating have any impact on the safety of the glass?
The windshield is rated for the car body, and there is no difference in the body structure of a hybrid camry or a gas camry.
Besides, how many times have you seen a custom car with different bumper covers? Is that also a serious safety problem?
Geez, I never thought that this post would have gotten me about 10 replies, but none answering the question or addressing the issue!
First, windshields are NOT "rated" for the car body, so you are just plain wrong (sorry, but if you're going to belittle an issue that could cause people to die, you get what you ask for).
The noise reduction rating is irrelevant. What is relevant is that Toyota chose to use a different windshield in the hybrid than the gas Camry. The hybrid weighs 10% more than the gas Camry. Windshields are designed to support about 30%-50% of the weight of the car in a rollover. Don't you think that there *might* be a chance that Toyota didn't just use a different windshield as a marketing feature, but instead did so because they were required to?
Of course, it may just be that I'm the only one that would prefer not to be crushed to death in an accident, and that people are more concerned with ugly windshields.
-Scott
Old Jun 28, 2007 | 01:13 PM
ag4ever's Avatar
Dazed and Confused
Originally Posted by rscott
If you have had your Camry Hybrid windshield replaced, please read this.
There have been a couple of threads about the Camry Hybrid windshields; the two main topics were that [1] the windshields often get replaced with the gas Camry windshield, and [2] there is concern that the Camry Hybrid windshield is more prone to cracking than it should be.
What I've discovered is that there could be a safety issue (actually, there *is* a safety issue unless it can be proven otherwise). I'm asking that you post (or E-mail me directly, if you prefer):
[1] Who replaced your windshield,
[2] Information on which windshield it was replaced with.
[3] Whether or not you informed someone that you thought it might be the wrong glass (and if so, what company and when).
For #2, you can look at the bottom of the driver's side of the windshield, and look for the M# and DOT#. As an example, the replacement I received was M334 and DOT376. If you have M334/DOT376 or M555/DOT404, it's a gas Camry windshield; if you have M3K4/DOT20, it's a Camry Hybrid windshield.
Specifically, I'm trying to find out whether this is a problem just with Safelite, whether it affects other auto glass companies (it could be a problem with a bad database entry somewhere), and whether or not these companies knew ahead of time that they were installing the wrong glass.
If all goes well, it is really the same glass, and Toyota just shouldn't have marketed the glass as if it were unique to the Hybrid. Next best would be if the glass is structurally the same, but acoustically different (in which case insurance companies would likely be required to replace with the correct glass). Worst case scenario is that the glass is structurally different to the point of a safety issue.
Thanks in advance to everyone who responds.
-Scott
P.S. If you are interested in more details about windshields and repairs/replacements, I'm compiling as much information as I can at www.carwindshields.info .
I don't see any real requests for information in your original post.
Again, I don't understand why you feel the Gas version's glass is unsafe.
Do you know what the GVWR is for each vehicle? Is the gas version's GVWR actually less than the Hybrid's?
Old Jun 28, 2007 | 01:40 PM
skywagon's Avatar
Thumbs up Re: Info if you have had your Camry Hybrid windshield replaced
-Scott
Scott, You will not get any argument form me as i have had a couple winshields replaced on Lexus vehicals and they most definetly are part of the structural integrity of the car Period!!!!
Old Jun 28, 2007 | 01:54 PM
Sooty's Avatar
GROSS VEHICLE WEIGHT
Camry XLE V6 = 2028 kg (4470 lbs)
Camry Hybrid = 2116 kg (4665 lbs)
Difference 88 kg or 195 lbs
CURB WEIGHT
Camry XLE V6 = 1595 kg (3516 lbs)
Camry Hybrid = 1669 kg (3680 lbs)
Difference 74 kg or 164 lbs
Source 2007 Toyota Camry Brochure downloaded from Toyota.ca
Old Jun 29, 2007 | 11:29 AM
ag4ever's Avatar
Dazed and Confused
How much structure can a windshield give the car in a roll over?
I am not trying to argue with you, but just from a different perspective, I can't see how there would be enough difference to make it a huge safety issue.
On a seperate note, I did see my first chip in my windshield. It is about the size of a ball point pen tip. Can a chip this small be filled?
Old Jun 29, 2007 | 12:23 PM
rscott's Avatar
An Enthusiast
I thought that "If you have had your Camry Hybrid windshield replaced ... I'm asking that you post ..." with 3 pieces of requested information was a real request for information.
Well, since I stated the difference, either I know or I am lying. Just go to http://www.toyota.com/camry/specs.html and click 'capacities.'
Old Jun 29, 2007 | 12:33 PM
rscott's Avatar
An Enthusiast
I don't know the mechanics of it, but it does.
For some more information about the support that a windshield provides, you might want to check out http://www.emsresponder.com/web/online/EMSRespondercom-Columns/Windshields-Under-Fire-Danger-in-Front-of-Your-Eyes/20$4543 (or http://www.ultrabond.com/whywindshields.pdf, although is a bit biased).
I'm pretty sure that it can; you could always check with a local auto glass place to find out. Chips often in time turn into large cracks (once they are about 6" in length, few places will fix them). Insurance companies often will pay the cost of a repair, regardless of your deductible, if you agree to the repair rather than a replacement (I would always recommend a repair over a replacement, if the windshield is the original one).
-Scott
Old Jun 29, 2007 | 01:16 PM
Sooty's Avatar
I might be missing something here but just where did you specify the GVWR of the vehicles? Also the link you provide only shows Curb Weight not Gross Weight, for the difference see my post above.
Ahhh found what you are referring to.
Boy you are stretching the point aren't you.
You must be comparing only a four cylinder Camry with the Hybrid.
If you want to compare them you must be fair and use the heaviest Camry that uses the non sound proofed windshield that would be the V6 XLE the difference is only 4.5% not the 10% that you state.
Cheers
Steve
Old Jun 29, 2007 | 05:55 PM
rscott's Avatar
An Enthusiast
Sorry, I'm from the U.S., and we sometimes forget that there are other countries out there. I was comparing the Hybrid with the heaviest gas Camry reported by www.toyota.com.
I'd really rather not debate whether curb weight or GVWR is better for determining safety issues, whether certain models that toyota.com doesn't advertise use the same glass as other gas Camrys, or what weight difference could justify needing safer glass. I don't have the expertise to answer those questions, and while there may be a few here who do, it's hard to rely on someone's stated credentials in a forum like this when it comes to a life-or-death safety issue.
So to the point: Could anyone who has had their Camry Hybrid windshield replaced please consider answering the questions in the first post in this thread? Thank you!
Old Jun 29, 2007 | 06:18 PM
Sooty's Avatar
Then you obviously didn't check out the site well enough because the heaviest gas Camry reported on that site is the V6 XLE at 3516 lbs Curb Weight
