I'm not happy with TCH low front clearance
Old Dec 1, 2006 | 12:48 PM
vioarc's Avatar
it's just a car...
Default I'm not happy with TCH low front clearance
It's been several months since I took delivery and over ten thousand miles. After getting used to the gizmos and fixing the console chirp, I thought the TCH was near perfect. The reality is, the leading edge of the front end is simply too low.
It just clears parking bumper wheel stops, but does not clear many curbs in real-world parking conditions.
I have scraped it several times, even after recognizing the problem and trying to be careful.
To make things worse, the clearcoat seems to peel back, making touch-up useless.
Old Dec 1, 2006 | 03:27 PM
nathanso's Avatar
Default Re: I'm not happy with TCH low front clearance
Mine scrapes too.. gotta go slow/diagonal over dips. The car's suspension is weak in general.
Old Dec 1, 2006 | 08:42 PM
FL07THC's Avatar
Mine got scrapped day 2
Old Dec 2, 2006 | 06:39 PM
gandyfire's Avatar
I am sure the ground clearance is to assist in FE but it is also too low to clear a racoon three days after delivery.
Old Dec 2, 2006 | 08:04 PM
CGameProgrammer's Avatar
I haven't had any issues with it, but then I'm always careful not to go too close to those parking barriers, since I used to have a VW Jetta whose front end was literally 2-3 inches above the ground, and regularly got destroyed. I finally removed it.
Old Dec 3, 2006 | 04:40 AM
pajasper's Avatar
Yep, I think it's all in what you're used to. The TCH doesn't scrape nearly as easily as our Buick LeSabre.
Old Dec 3, 2006 | 05:47 AM
TCH2007's Avatar
Olde Farte
Totally agree!!! The TCH has the ground clearance of a jeep compared to a S2000!!!!
Old Dec 3, 2006 | 01:35 PM
Pete4's Avatar
TCH is not any different than most sedans. Lowest point is about 6.5 inches off the ground, just about average for passenger car. I bet most of you not happy with clearance drove SUV before, which usually have higher clearance, since originally they were designed for off road driving. I have no problem clearing the curbs, except for really high ones and learned my lesson long time ago not to drive forward until I hit the curb.
Old Dec 3, 2006 | 03:50 PM
juicius's Avatar
My previous car was '02 F150 and I'm used to pulling the truck up real close. I more or less had to since the length was longer than most cars and some of the urban parking lots are designed to cram as many vehicles in as possible. With TCH, I know I don't have to get as close to the curb as before so I haven't had an issue with the ground clearance.
mpg50
Sep 10, 2012 11:42 AM
Droid13
Dec 12, 2008 04:06 AM
nicst47
Nov 27, 2007 09:41 PM
Gobbles
Oct 18, 2007 07:15 AM
tecis
Sep 2, 2007 03:54 PM
