ICE started up immediately
Old Sep 14, 2006 | 04:58 AM
Orcrone's Avatar
Default ICE started up immediately
It always takes about 10 seconds for the ICE to turn on after starting up the car. This morning the ICE turned on immediately and felt pretty rough. Within about 10 seconds it was running normally. Has anyone else had the ICE start up immediately upon starting the car?
Old Sep 14, 2006 | 06:08 AM
skywagon's Avatar
Default Re: ICE started up immediately
Neverhad this happen, may have a sensor problem.
Old Sep 14, 2006 | 02:50 PM
acco20's Avatar
If it is cold out, or cooler than it has been, the ICE will start immediately, to warm things up. After warm up, it should go back to normal. At least this is how I understand it.
Old Sep 14, 2006 | 05:41 PM
FL07THC's Avatar
I have never had this happen, however sometime ICE kicks in and out more rough than other times.
Old Sep 15, 2006 | 03:15 AM
Orcrone's Avatar
It's still 80 degrees here. Aside from which the car was sitting in the garage.
One thing I did notice is that when I started the car the temp gauge was reading higher than it normally does on startup. It hasn't done it except for that one time.
Old Sep 15, 2006 | 05:31 AM
RCFlyer's Avatar
My guess is if there was an issue - with all of the computers in these things - it will notify you....
Old Sep 29, 2006 | 04:47 AM
Orcrone's Avatar
It happened again. Started the car and waited for the beep to put it in reverse. The ICE started up immediately with no delay. I noticed another thing. Normally everything turns on slowly. For instance the fan on the climate control system will not turn on immediately and when it does it gently and gradually (over several seconds) gets up to speed. This morning it immediately came on full blast.
I know it's not as bad as what Norb and Charlesc had happen to them. But it does make me wonder.
Old Sep 29, 2006 | 06:29 AM
Droid13's Avatar
HSD Organic Interface
If this happened to me, I'd be checking SoC first to see if it's ususually low. If it's not, it almost seems like the computer thinks it's already in "ready" mode instead of initializing ready mode.
I'm still pretty diberate with my On and Off cycles because I made a few goofs being to casual turning on and going off earlier on...
Old Sep 29, 2006 | 06:47 AM
Orcrone's Avatar
Originally Posted by Droid13
If this happened to me, I'd be checking SoC first to see if it's ususually low. If it's not, it almost seems like the computer thinks it's already in "ready" mode instead of initializing ready mode...
Droid. Good point. My SOC was pretty low this morning. I don't remember how it was the first time it happened.
I actually threw it in reverse very quickly after hearing the beep... almost at the same time. Perhaps I'll be a little more deliberate.
ReaverKS
May 30, 2013 02:15 PM
Brandon Williams
Nov 2, 2012 11:18 AM
LeeS
Sep 1, 2011 03:44 AM
gpsman1
Jan 28, 2008 01:04 PM
Jason
Our Announcements
Mar 26, 2005 09:47 PM
