Hybrid system check after replacing hybrid battery pack
Old Sep 13, 2023 | 10:46 AM
Default Re: Hybrid system check after replacing hybrid battery pack
Originally Posted by Chuckybost
Keith,
Thank you for the quick analysis and much appreciate.
Already paid the garage and he is will to replace five recondition modular. 15,16, half on 11.
block 1 and 17 look very strong so I will ask him to mix with block 9 and 12.
Any other recommendation?
There's no guarantee the shop will successfully replace anything. There are two modules in blocks. Splitting/mixing 1 & 17 with 9 & 12 may be counter productive.
Clearly the garage is unable to identify strong/weak modules, and clearly has no build standards.
You have been ripped off. You should try to get your money back. Even if you drive out of there without a P0A80, you have no confidence that this pack will last long enough to justify the expense.
Old Sep 14, 2023 | 06:33 AM
Chuckybost's Avatar
Keith,
Thank you for all your responses.
For 2014.5 Camry Hybrid, how is the battery count? Does block 1 begin on the BMS side? Can modular +/- terminal swap? (For example, does modular 1 positive pointing to the front of the car) Do you know where I can find a hybrid battery map?
chucky
Old Sep 14, 2023 | 07:07 AM
Sorry I don't. I use my own convention for module numbering because I direct test individual modules and don't use block data for anything. It is not consistent with Toyota convention on some models, and Toyota is not consistent across models.
hopmedic
Aug 28, 2021 09:37 PM
inzar
May 7, 2021 11:38 AM
Amjadov
Jul 16, 2020 06:57 PM
evilpotato
Sep 29, 2018 11:53 AM
