HUGH drop in mpg...Why??Suggestions?
Old Jul 19, 2008 | 06:17 AM
LOL TCH's Avatar
Default Re: HUGH drop in mpg...Why??Suggestions?
Could ethanol be part of the problem? My mileage has dropped about 10% since all the gas stations in Tampa made the switch.
Old Jul 21, 2008 | 06:14 AM
test54's Avatar
I did read on here that you can expect about a 10% drop in mileage when you use it.
Old Jul 21, 2008 | 08:25 AM
skywagon's Avatar
Don't beleive everything you read or hear, a friend has one and runs strickly e-85 which is 85% alkie and gets 40 to 46 MPG all the time, boils down to learning how to drive period.
Old Jul 21, 2008 | 08:40 AM
haroldo's Avatar
Q: How does ethanol affect gas mileage?
A:While there are many variables that affect fuel economy (weather, car condition, road grade, tire pressure, air conditioner use, etc.), studies indicate that fuel economy with ethanol-enriched fuels may decrease, but not likely with E10. E85 has approximately 27% less energy then gasoline, but fuel economy loss varies between 10 to 25%.
Source
Old Jul 21, 2008 | 09:18 AM
test54's Avatar
ok so it has less energy, just not sure how much less.
Personally i avoid the stuff whenever possible. Its not a solution for anything in my opinion.
Waste of time and money by Washington to mandate its use to help out corn growers while avoiding the real problem of burning oil / alcohol products in cars.
http://priuschat.com/forums/fuel-eco...d-e10-e85.html
Old Jul 21, 2008 | 10:14 AM
haroldo's Avatar
...MTBE (a winter additive) also kills mileage.
Old Jul 21, 2008 | 12:23 PM
  #27
GeorgiaHybrid's Avatar
Larry,
The article is from a site that promotes ethanol use. The link below is from CNN and states that E85 selling at 3.30 a gallon is equal to paying 4.34 a gallon for gasoline. It depends on which way you want your statistics, uh I mean lies, uh.. numbers yeah, numbers sounds right, to work.....
Your mileage will be 31.5% more than ethanol or 24% less than gasoline
http://money.cnn.com/2008/07/21/news...ion=2008072106
Old Jul 21, 2008 | 01:00 PM
  #28
haroldo's Avatar
I wasn't supporting it nor ridiculing it, although IMHO, it's the dumbest idea since .... (let's just say that there have been a number of short sighted politically motivated mistakes made over the last few decades, and leave it at that).
I just Googled it and posted my findings.
Old Jul 21, 2008 | 02:02 PM
  #29
FastMover's Avatar
Old Boomer Techie
Personally i avoid the stuff whenever possible. Its not a solution for anything in my opinion. ...Waste of time and money by Washington to mandate its use to help out corn growers while avoiding the real problem of burning oil / alcohol products in cars.
Not to mention that Alcohol is a solvent more so than gasoline. I still don't buy the idea that the presence of Ethanol does not impact the oil barrier coat on the valve guides and rings. It can't do them any good.
Old Jul 21, 2008 | 03:28 PM
  #30
haroldo's Avatar
Not an expert, but I believe Indy cars use 100% ethanol and NASCAR fans blood is 20% alcohol. (j/k)
