How to calculate MPG
Old Jun 5, 2006 | 07:14 AM
  #51
TKCamry's Avatar
2007 Toyota Camry Hybrid
Default Re: How to calculate MPG
When you get to the edit signature area, click on the insert picture button. Then when the pop up comes up for the link, paste the link in there. That will insert the picture into the signature area.
Old Jun 5, 2006 | 07:17 AM
  #52
WVGasGuy
Guest
Posts: n/a
That worked, THANKS!!!!!!!!!
(now if I can just get this up to 38_my last 1400 miles have all been over 39 mpg_it's a slow climb)
Old Jun 5, 2006 | 09:44 AM
  #53
CGameProgrammer's Avatar
You should make your picture a link though. Notice you can click TKCamry's and my signatures to view our individual tanks.
Old Jun 5, 2006 | 10:01 AM
  #54
WVGasGuy
Guest
Posts: n/a
OK I give up. Now I have a link to my picture and my picture as well. Neither takes me to the data base. Have patience with me, you'll notice I'm 2x your age and living with a whole different world view.
Old Jun 5, 2006 | 04:53 PM
  #55
You want this: (replace parentheses with brackets)
(url=https://www.greenhybrid.com/compare/mileage/car/2875.html)(img)https://www.greenhybrid.com/compare/mileage/car/2875/signature.png(/img)(/url)
Old Jun 7, 2006 | 12:25 PM
  #56
WVGasGuy
Guest
Posts: n/a
I had it working, it quit again this morning, but after resaving I believe it's OK
Old Jul 5, 2006 | 06:27 AM
  #57
bmgoodman's Avatar
OK, not sure my sig graphic works, either.
Old Jul 5, 2006 | 08:00 AM
  #58
WVGasGuy
Guest
Posts: n/a
For a signature that not only updates but takes you to the database for your vehicle by clicking, follow the directions in #55 that CGameProgramer gave me. You probably only need to change the vehicle number to get it to work.
Old Jul 5, 2006 | 09:54 AM
  #59
bmgoodman's Avatar
I actually had already done exactly that, or at least I thought so. I copied the string into Notepad, did a search for "(" and replaced with "<" and ")" and replaced with ">". I then replaced 2875 with 2987.
OIC! He said brackets, but I thought HTML used <>. Went back and used square brackets [] and it worked. Thanks for your help!
Old Jul 5, 2006 | 09:59 AM
  #60
WVGasGuy
Guest
Posts: n/a
Everyone here should update their "signature" it's a pretty neat function
