Hey NAV users, look what I found
Old Feb 17, 2007 | 11:38 AM
  #51
B-Red-TCH's Avatar
Default Re: Hey NAV users, look what I found
Can anyone tell me if the TSB is an upgrade to v6?
Old Feb 17, 2007 | 01:52 PM
  #52
spiff72's Avatar
My understanding is that it is NOT an upgrade to map version 6. It may also take away your override functionality if you have version 5 (if I recall correctly).
Old Feb 19, 2007 | 02:26 PM
  #53
Beckel's Avatar
Thanks to everyone for the very detailed instructions on hacking the DVD. I was able to get the DVD working on the first try. No issues.
Thanks again...
Old Mar 13, 2007 | 07:49 AM
  #54
mr.pete's Avatar
Default Do NOT upgrade!
I have a 2004 LS430 that had the original map DVD until I took it in for service the other day. I decided what the heck--let's update to 6.1 while I'm in there. I lost the override feature, as you might have guessed. I didn't know it until I went to use the Nav today. I'm totally angry about the fact that the dealer didn't tell me about this "downgrade" --AND the fact that they didn't give me my original DVD to take home (even though I own it). I have a call into their service dept looking to get it back! If anyone would like to swap a COPY of their v5.1 DVD for a copy of my v6.1, that would allow us to try burning a "hybrid" disc like the one mentioned above.
Old Mar 13, 2007 | 07:56 AM
  #55
schmidtj's Avatar
Keeping Toyota Solvent
If you got the "free" replacement for the inaccurate position problem then it should still be a 5.1 DVD. In which case you have no right to keep the old "defective" DVD.
If you paid an "upgrade" price then you still can't use the old DVD. Read the license.
If you paid "full price" for a new version of the NAV software you should be able to keep the down level DVD.
So what applies to you?
Old Mar 13, 2007 | 03:22 PM
  #56
skata's Avatar
Default Re: Do NOT upgrade!
Actually you only need the LOADING.KWI to make the hybrid 6.1 with the override feature. I downloaded a copy of the file from a link off this forum.
Old Mar 13, 2007 | 03:52 PM
  #57
Sooty's Avatar
Just to screw things up a little bit I got the "free" replacement for inaccurate positioning and got a Version 6.1 DVD.
Didn't keep the old 5.1 DVD but have a copy of it on my hard drive.
As a matter of interest it did not fix the positioning problem. Which lends more credence to the argument that the "free" replacement is just a ruse by Toyota to get rid of the override feature.
Old Mar 14, 2007 | 05:31 AM
  #58
wilsons66604's Avatar
Led-footed HyBrid geek
When I changed DVD versions (6.1 to 6.modified) I had to unplug the number 12 fuse under the hood for the NAV system to reload the disk and see the changes. Could this be your problem?
Just a thought
Old Mar 14, 2007 | 06:51 AM
  #59
Sooty's Avatar
Just a thought
I didn't change the DVD the dealer did while the vehicle was in for other work, so it's possible they didn't do that.
But all the settings had changed back to defaults Kms changed back to Miles etc, so I'm presuming they did it correctly.
Edit: I thought I had read somewhere that when going from an older version(5.1) to a newer version(6.1) that the system word automatically load the newer firm wear or such. Resetting was only necessary if you want to go backwards to a previous version.
Old Mar 14, 2007 | 01:44 PM
  #60
ag4ever's Avatar
Dazed and Confused
The nav will automaticly upgrade the software when a newer version is put in, it won't automaticaly down-grade. hence the reason you have to pull the fuse to force a reload of the software.
