Heat-A/C unit - How does everybody use their's?
Old Oct 20, 2006 | 10:36 PM
Pete4's Avatar
Default Re: Heat-A/C unit - How does everybody use their's?
The reason for electric motor running compressor is to provide AC when ICE is stoped. I would imagine compressor would either cycle or run different RPM's, but I would lean towards cycling, probably is more efficient but there is really no way to tell for sure. I can not tell when compressor is running and when it is not.
Old Oct 21, 2006 | 09:29 AM
alc13's Avatar
This is a great thread. For those less mechanically-inclined of us, I gather a reasonable setting for the climate controls is ECO on, AUTO on, and AC on, with adjustment of temperature as needed. This will provide comfort without excessive energy use. Am I on the right track?
Old Oct 21, 2006 | 05:29 PM
Paulgw's Avatar
From the TCH Manual:-
The A/C amplifier calculates the target speed of the compressor based on the target evaporator temperature (which is calculated by the room temperature sensor, outside temp. sensor, and the solar sensor) and the actual evaporator temperature that is detected by the evaporator temperature sensor in order to control the compressor speed.
Old Oct 21, 2006 | 05:41 PM
Paulgw's Avatar
This from the TCH Manual gives a little more insite into the ECO mode:-
During cooling under ECO mode control, the cabin temperature is maintained at 25°C (77°F) even if the set temperature is below 25°C (77°F). Since the power consumption of the electric inverter compressor is limited under ECO mode control, this does not indicate a malfunction.
To decrease the cabin temperature to below 25°C (77°F), the MAX COLD temperature (18°C (64.4°F)) must be selected or ECO mode control must be canceled by turning the ECO switch OFF.
Old Oct 22, 2006 | 06:40 AM
kluken's Avatar
This is the first car I have left on AUTO mode. I leave it on AUTO ECO mode and set temp accordingly. The one thing I did not that it seems there is a fine line between cool and warm air. I find that if I am comfortable it is possible the TCH will start blowing cool air, and if I want to bump it a degree or 2 then I notice some warm air starting to come from the vents. You would think they would have a 1-3 degree range where they would not cycle back and forth between AC and heat. During the warm months this was fine as it stayed in minimal cool mood, but during the fall I suspect I may override the AUTO a bit.
biglinda
Jul 18, 2017 01:18 PM
misermiester
Mar 27, 2017 03:59 PM
noflash
Feb 28, 2007 10:11 AM
Kumfy Kitty
Introductions
Oct 3, 2006 02:34 PM
mochisushi
Introductions
Oct 9, 2005 06:15 PM
