Front / rear weight distribution
Old Jun 11, 2006 | 01:14 PM
spiff72's Avatar
Default Re: Front / rear weight distribution
Originally Posted by stevenvillatoro
Honda Insight owners are probably the most obsessive (not in a bad way) about mileage issues, including tire PSI, nitrogen, etc. You will find excellent discussions about nitrogen at insightcentral.net. I was looking at that topic last night on their site, and read that tire air compressors (the type you find for public use outside of gas stations) use 79 percent nitrogen. It seemed that people concurred there was no real reason to use nitrogen unless you were driving a race car that might be prone to blowouts... since nitrogen does not alter tire pressures as it heats up. If any of my info was stated incorrectly, will someone hit me over the head with a Smart Key, please?
I think Nitrogen is a gimmick.
The earth's atmosphere is about 78% nitrogen (I am guessing that is why you made that comment in your post).
Old Jun 11, 2006 | 01:32 PM
stevenvillatoro's Avatar
Arrow Re: Front / rear weight distribution
Okay, okay... you caught on, and yet I was off by one percent. Bad memory. But, in my defense, the reason for my percentage error is that I'm apparently severely oxygen-starved, with my brain running on just 21 percent of the stuff, as seen below. Krypton... hmmm, now I'd like to get ahold of some of that!
Gas volume of our atmosphere:
Nitrogen (N2) 780,840 ppmv (78.084%)
Oxygen (O2) 209,460 ppmv (20.946%)
Argon (Ar) 9,340 ppmv (0.9340%)
Carbon dioxide (CO2) 381 ppmv
Neon (Ne) 18.18 ppmv
Helium (He) 5.24 ppmv
Methane (CH4) 1.745 ppmv
Krypton (Kr) 1.14 ppmv
Hydrogen (H2) 0.55 ppmv
Not included in above dry atmosphere:
Water vapor (highly variable) typically 1%
ppmv: parts per million by volume
Old Jun 19, 2006 | 06:13 PM
TKCamry's Avatar
2007 Toyota Camry Hybrid
Originally Posted by TKCamry
I called Toyota at 1-800-331-4331 and got the answer to your question.
The weight distribution for the Camry Hybrid is 54% Front and 46% Rear.
I also, at the same time asked the question thru an email, and got this different answer today.
Response (James)06/19/2006 05:54 PM Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
Figures must be taken as approximate due to variances in option load, etc:
Front kg (lb) 950 (2094.4)
Rear kg (lb) 700 (1543.2)
Total kg (lb) 1650 (3637.6)
Approx 57 percent front, 43 rear.
Toyota Customer Experience
Pick which answer you like, but the email seems closer to reality.
JoeVsFox
Jun 18, 2012 01:05 PM
stevenvillatoro
Apr 16, 2009 12:53 PM
exbauer
Mar 3, 2009 09:19 PM
mikieboyblue
Jan 19, 2008 07:34 PM
Delta Flyer
Off Topic
Apr 8, 2006 03:29 PM
