failed weld between exhaust manifold and cat/converter
Old Nov 2, 2011 | 06:39 AM
lincolnshibuya's Avatar
Default Re: failed weld between exhaust manifold and cat/converter
just throwing off some ideas and I'm not a salesperson, If you want the forums to be alive don't shush people off, this is what the forums are for unless people are posting spam or trolling around. I don't make any profit from it.
Old Dec 4, 2011 | 07:08 PM
fullofbeans's Avatar
Electricity Guzzler
I"ve got a loose "heat shield" about couple of feet before the muffler.
I first thought it was part 14, but that looks like it wraps around the muffler so that's not it.
http://www.dealerdirectparts.com/v/v...os/8522290.gif
I tapped it with a stick and see and hear it's loose. Going over bumps I hear this metalic rattle. Reading this post I thought at first it was my issue but probably not. This small metal "heat shield" is now resting on part 6 in the picture. I cna't find a proper pdf to see the part or part #. I'm not even sure it it was simply 4 bolts that came loose or what. -ideas? tx
Old Dec 4, 2011 | 08:29 PM
the kentucky-built and japan-built TCH has some slight differences in the bracket.
here's a site that has the detailed parts;
http://www.partswebsite.com/pagetoyo...25&catid=30152
the detailed parts layout for japan-built TCH;
http://www.facebook.com/photo.php?fb...type=1&theater
could be a bad bracket or heat shield not shown in the parts layout.
kuzzinpaul
Aug 6, 2018 07:03 PM
thanksjc
Aug 7, 2013 11:44 AM
GaryG
Jul 7, 2011 11:46 AM
vin888
May 20, 2008 09:12 AM
GatorJ
May 29, 2006 04:49 PM
