failed weld between exhaust manifold and cat/converter
Old Oct 7, 2011 | 11:28 PM
BlueCam's Avatar
Default failed weld between exhaust manifold and cat/converter
The problem:
My 07 Camry Hybrid suddenly sounds like a Honda Punk-Mobile that any high school student would love to cruise with.
The diagnosis by a Toyota Dealership Mechanic:
A weld has failed somewhere between the engine exhaust manifold and the expensive bits of the exhaust catalytic converter.
The Solution:
The Toyota dealership said that they could fix the problem by replacing parts but with labor it would cost $ 1,500.
However, when I asked, I could probably take it in to a muffler shop and have it all welded back together for a tenth of that cost.
So I am going to ask my local dealership to recommend a good muffler/exhaust place.
I will keep you all updated on my progress.
Old Oct 8, 2011 | 04:37 AM
Ed_T's Avatar
TCH 2007 newbie May 07
Default Re: failed weld between exhaust manifold and cat/converter
pLease do, my -07 has 90-add thousand miles and I'm debating a trade-in...
thanks
Old Oct 8, 2011 | 08:37 AM
ukrkoz's Avatar
you have Meineke around, don't you?
Old Oct 9, 2011 | 02:03 AM
BlueCam's Avatar
Update...
Just learned that Toyota and Honda are known for welding catalytic converters right to the exhaust manifold outlet.
Old Oct 9, 2011 | 02:18 AM
BlueCam's Avatar
Update...
My Camry is close to 98K miles. Sorry, should have stated this earlier.
Old Oct 9, 2011 | 08:19 AM
ukrkoz's Avatar
Personally, I can bolt this on DIY
http://www.am-autoparts.com/Toyota/C...tm_content=CCD
Old Oct 9, 2011 | 08:21 AM
ukrkoz's Avatar
even if you go this route:
http://www.dealerdirectparts.com/Pro...233-CAMRY-HY-4
it's still 50% dealership cost.
Old Oct 9, 2011 | 11:19 AM
jetttstream's Avatar
Originally Posted by ukrkoz
I like that price!
Old Oct 9, 2011 | 12:45 PM
ukrkoz's Avatar
everyone needs to keep in mind that there's something too cheap about that price.
but, for the purpose of this thread, i need to highlite few points:
1. cat is not part of exhaust manifold; it is on some Camrys, not on this one though
2. it appears to be a simple bolt on replacement that can be done off jackstands
3. even if the end user does not have skill/tools. or desire to DIY this, it is wise to buy the part and have it swapped out at, say, same Meineke
4. I had weld jobs done before by Meineke. I still say that vehicle needs to be inspected by a pro muffler shop, like Meineke, and possible repair discussed with them. Hoping for a forum to provide medicine to fix it is non-realistic.
Old Oct 9, 2011 | 08:59 PM
lincolnshibuya's Avatar
Go to rockauto.com, check the part below. look for shops near you that could install this part for you if you're not a DIY. find another dealer/mechanic looks like the dealer mechanic is just throwing parts at you. Looks like an easy job for a DIY.
EASTERN CATALYTIC CONVERTERS Part # 40483 48" Overall Length; 1 Front Gasket; 1 Rear Gasket
DIRECT FIT; w/ CA EMISSIONS - USA BUILT; Rear; Not legal for sale or use in the state of California
* Non-stock item--shipping delayed up to 3 business days
$192.79
