Dumb button placement, good catch
I've questioned why the 'ECO' switch is down to the left, by the fuel door release button. Others have lamented the fact that many buttons are not illuminated. Some have wondered why 'ECO' mode seems to develop a mind of its own and turn off.' Put the three together, and this is what you get: Last night, I noticed the 'ECO' mode was off, reached down to turn it on, couldn't tell which button was 'ECO' and which was the fuel door, took a chance and pressed a button. Nothing happened. So I pressed the other and the 'ECO' mode came back on.
Here's the good news: the accidental press of the fuel door button didn't activate since (I think) the car was moving. Good catch by some engineer.
Re: Dumb button placement, good catch
The ECO button placement was the first 'goof' (and maybe still ranks as the most blatant to me) that I noticed when I got my TCH. There's almost no way you can see when it's illuminated to show that ECO is on. Luckily, the other ECO indicator in the center console, although small, will show you at a glance whether it's actually on.
One possible solution to 'fumbling for the ECO button' is to cut a small square of self-adhesive velcro (The hook side) and stick it to the ECO button.Then you can easily feel the button in the dark and not accidentally open the fuel door while driving!..
If you are a bit cautious when wanting to push the ECO button, you can use your fingernail to feel the little rectangle for the light. Also, the gas tank button is quite a bit farther to the left under the mirror adjustment. I think just being aware of which one it is (right) will make it easier.
