dashboard rattles
Old May 11, 2008 | 01:30 PM
vin888's Avatar
Default dashboard rattles
i have a rattling sound on the driver side on my 09 TCH anyone has also this problem?
Old May 11, 2008 | 01:53 PM
backupguy's Avatar
Default Re: dashboard rattles
My 09 does not have anything like this.
Old May 11, 2008 | 06:17 PM
jbrandt04330's Avatar
Search this group for "console crickets" - Very common problem. Mine worse in winter/cooler months.
Old May 12, 2008 | 09:08 AM
mikieboyblue's Avatar
A real easy test to determine a solution is take some cardboard, fold it to be about a half inch thick, and stuff it between the dash and windshield (between the driver side speaker grill and the large semi-circle piece where the clock is). Move it around or add others if the noise does not stop. I currently have a piece in my car.
Once you have determined the location of the noise, acquire some black foam (pipe insulation works well) and stuff it in the needed locations.
Old May 13, 2008 | 08:51 AM
robs24's Avatar
I have rattles coming from the dash area as well, I was going to take it to the dealer and see if they can fix it. I realize that I can fix it with some foam...but should'nt the dealer take care of this?
Old May 14, 2008 | 08:05 AM
Depends on how good your dealer is. You run a very high risk of having more problems when you get the car back. There are a number of horror stories in this forum. I don't trust mine.
On a side note, I still have not figured out what sounds like a piece of plastic bouncing around in my car. It wasn't there before (for the last year) and just started. I thought it was my sunglasses because I moved them and the sound was gone for a day but now it is back! It is random...and it sounds like it is coming from above my head. Since I need to be in motion and on a CERTAIN kind of terrain to here it, it is a pain in the butt to diagnose (while driving).
Old May 14, 2008 | 12:28 PM
bmgoodman's Avatar
My dealer would fix this by following the TSB issued for the issue. This fix requires removing the steering wheel and the entire dash. I've seen pictures in this forum and all I can say is . I don't trust these guys to take everything apart, apply the fix, and reassemble everything without causing other problems.
The dealer would not offer to do anything else because apparently they may not get reimbursed by Toyota since they would not be following the approved procedure.
I'm going to stuff some rubber in there myself. I'll post my results whenever I get around to doing this. I've been living with tacky cardboard for about 2 months now....
Old May 14, 2008 | 12:36 PM
coolshock1's Avatar
Driving in stealth mode
Just remember not to block the front air ducts for the climate control system. I remember reading about someone doing that and then having to move or remove some of the foam.
Old May 14, 2008 | 12:52 PM
Yeah, I really don't think that part is true. The vents in my car are just past the close and not right along the line between the dash material and the glass.
Old May 14, 2008 | 01:33 PM
coolshock1's Avatar
So you're saying I'm lying about reading that??
