Coolant Service for my Camry Hybrid problem
Old May 4, 2013 | 04:26 PM
Ron AKA's Avatar
Default Re: Coolant Service for my Camry Hybrid problem
Originally Posted by ptung07
Thanks everyone! This forum is great.
From this point on, should I be doing a drain/fill of the coolant every 100,000 miles because it is still the Toyota Super Long Life Coolant? In addition, how long/many miles should I also be doing the drain/fill of the transaxle ATF since I also just changed it?
Toyota says the following for the 2012 TCH coolant circuits:
"Initial replacement for engine coolant is at 100,000 miles/120 months and for inverter coolant initial replacement is at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter."
I think they are allowing for the potential that a service replacement is not a complete replacement.
On the transaxle, I don't recall Toyota recommends that any replacement of the fluid is necessary. So, it would be your call.
Old Dec 21, 2021 | 04:28 AM
FLHybrid's Avatar
Originally Posted by GeorgiaHybrid
Glad we could help out. The problem you encountered is one of the main reasons I invested in a vacuum fill for my cooling systems. It is not real bad with the engine in the Camry but some of the GM cars can be a bear to bleed.
Old Dec 21, 2021 | 04:38 AM
FLHybrid's Avatar
For GerogiaHybrid: I too have a vacuum system I use for my 2006 Prius for the inverter and radiator coolant (done many times, now has 400,000 miles). I now have a 2018 Camry Hybrid that has reached 100,000 miles for the radiator coolant change. Instead of Techstream, putting the car in maintenance mode, etc., I suppose just using the vacuum for both the inverter and radiator should suffice, yes?? It's so simple and of all the coolant replacements I have done with the Prius I have never had a problem and the fluid volume drained always matched fluid replaced.
Defender
190
Feb 18, 2021 06:05 PM
GeorgiaHybrid
Jan 2, 2020 10:55 AM
GQinABQ
Saturn Vue Green Line
Jun 28, 2019 02:37 PM
Any3681
Jul 27, 2015 01:38 PM
JTirak
Sep 8, 2008 11:45 AM
