cleaning front door speaker plastic grill
Old Jul 20, 2010 | 11:53 PM
miller351's Avatar
Default cleaning front door speaker plastic grill
Long story short, soda got spilt on my TCH drivers door and I can't clean the speaker grill very well.
Is there a way to remove just the plastic grill piece covering the speaker in the front drivers door? If not, how difficult would it be to remove the whole drivers door inside panel? Are there websites for these types of parts removals?
Old Jul 21, 2010 | 06:38 AM
SanAntonio Joe's Avatar
Default Re: cleaning front door speaker plastic grill
Most cars today have a one-piece door panel that contains the speaker grill, and the speaker itself is anchored to the steel innner door skin. On some cars, you must remove snap-on access panels and several screws before removing the door panel. And, often, there are plastic clips holding the door panel in place that will likely break when you remove the panel. They can run $2-3 for each clip, and there may be as many as 5-7 clips holding the door panel in place.
As for cleaning the grill, try using some Q-tips soaked in a mild cleaner such as Simple Green on the grill openings to see if you can get far enough into the openings to remove the stain.
Good luck.
KimikoPi
Aug 1, 2010 11:56 AM
spmrebel
Mar 5, 2009 12:35 AM
elsifer
Aug 4, 2007 07:15 AM
mikieboyblue
Mar 21, 2007 05:14 PM
Z71
Jul 31, 2006 05:51 PM
