Check VSC warning and skid light when driving at steady speed
Old Jan 19, 2013 | 09:05 PM
GeorgiaHybrid's Avatar
Default Re: Check VSC warning and skid light when driving at steady speed
Originally Posted by Frodo
One thing that might trigger that - uneven tires. If there is a notable size variance between tires (e.g. one or more being worn, or them being different sizes), you could get enough rotational difference to have the ECU suspect a skid.
The period between the spastic episode is what caused me to suspect that direction...
Originally Posted by restamp
OTOH, the TCH comes with a space-saver spare and I presume this doesn't set off a VSC warning. My guess: it's probably a faulty wheel sensor.
You hit it restamp, the space saver tire and the different rotational speeds on the inside and outside tires in a turn are fine. What the system is looking for is a skid (no rotation at all) which can be caused by a bad sensor, bad wiring, loose connection, bad plug on the ECU connection or a bad ECU (the most common issues).
Mikejl
Apr 25, 2022 02:38 AM
noproblem07camry
Aug 26, 2020 03:00 PM
AudHCH
Mar 1, 2014 10:27 PM
SadCarTime
Jul 9, 2012 08:05 AM
minecamry
Feb 2, 2011 01:43 PM
