Check VSC System - Multiple warning lights permanently on
Old Mar 5, 2018 | 03:43 PM
Default Re: Check VSC System - Multiple warning lights permanently on
How were codes checked?
Old Mar 5, 2018 | 04:05 PM
ccwillet's Avatar
Old Mar 5, 2018 | 04:07 PM
ccwillet's Avatar
It was done at a dealer. Everything I replaced was at a dealer.
Old Mar 5, 2018 | 04:10 PM
Toyota dealer?
Old Mar 5, 2018 | 04:56 PM
ccwillet's Avatar
Toyota dealer?
Yes Sir. I have had to replace the steering angle, the Id box and the key fob ecu to even get it to except the key again. ( Do to the water damage). After I did that, the key took and i pushed the start button...it sent power to the new inverter for 2 seconds and stopped. Since then I replaced the hybrid relays in the battery because when I sent power to them, the scan tool told me they didn't turn on. The only thing it shows is the 12volt battery in a yellow top not the "Toyota 12v". So the yellow top doesn't have the battery temp sensor. That is the only thing in codes.
Old Mar 5, 2018 | 05:54 PM
Sorry, I got nothing. Flooding + 2 year sit may be a death sentence. If any of the 14+ computers were submerged, they're probably toast. I've encountered one Prius that was completely dead in the water besides a CEL and single click of the HV relay vs. the two normal clicks. No codes. No other signs of life besides lights. Supposedly, somebody did something that resulted in a couple of fuses popping.
Old Mar 5, 2018 | 06:00 PM
ccwillet's Avatar
Old Mar 5, 2018 | 06:09 PM
ccwillet's Avatar
I say water damage but really nothing got submerged. I think the moisture in the car did the ecu's in. But other then knowing I had to replace them because the scan tool told they weren't working. Nothing else is pending. I'm running out of thoughts and processes to follow
Old Aug 26, 2020 | 03:00 PM
Larry West's Avatar
Originally Posted by Azzam Al-Masri
Whats the purpose of VSC coming out twice in 1 week, what's the reason it happens to the car !
Mikejl
Apr 25, 2022 02:38 AM
nass_a_b
Jan 19, 2013 09:05 PM
zebrajeb
Sep 12, 2012 07:50 PM
phenderson
Dec 23, 2008 09:51 PM
Scooters
Jun 17, 2006 08:31 PM
