Center console lid replacement
Old May 9, 2017 | 06:57 PM
cbrookhart's Avatar
Default Center console lid replacement
I need to replace the lid on the center console for the 2007 Camry. I asked about this at the last service I had at a Toyota dealer. Apparently, the entire console has to be replaced; it's not possible to replace the lid.
I'd actually be more interested in just putting some tape on the lid. Would it be a correct assumption that it will be difficult to find a matching tape color?
Old May 9, 2017 | 08:39 PM
ukrkoz's Avatar
Default Re: Center console lid replacement
which lid? There are two. One next gear shifter and one above it.
One lower can be removed with console grey plastic piece it is in. Clips. Upper is removed as you see. Enture console does not need to be removed.
Old May 9, 2017 | 09:17 PM
cbrookhart's Avatar
The lid which needs replacing is the upper one between the two front seats.
Old May 11, 2017 | 09:15 PM
ukrkoz's Avatar
Ok.... There is no UPPER lid between two front seats. There is armrest that sides as storage compartment. You cracked that one? I can surely see that happen when elbow is jammed into it.
It's hinged, right? Whatever is hinged is removable.
File Type: gif
Old May 11, 2017 | 09:16 PM
ukrkoz's Avatar
What is wrong with dealers that they don't want to unclip one piece of plastic and undo 4 god **** screws?
HybridFan
Sep 18, 2008 03:11 PM
vioarc
Sep 3, 2008 05:05 PM
BJM5499
Jun 14, 2007 10:07 AM
montush
Oct 29, 2006 12:02 PM
timcob
Oct 22, 2006 12:52 PM
