camry hybrid 2007 - back side carpet wet
Old May 8, 2014 | 10:21 AM
Ron AKA's Avatar
Default Re: camry hybrid 2007 - back side carpet wet
Originally Posted by alpha_1976
I checked the moonroof drain and even those look OK. I have decided not to remove the carpet right now as it's drying pretty quickly with fan and I'll keep on doing it until it's really dry.
You may want to try to remove the sill plates -- should be just a few screws. That may allow you to lift the carpet on the door side enough to help it dry.
Old May 20, 2014 | 05:24 PM
alpha_1976's Avatar
Thanks everyone. I just wanted to update you -
This was really very annoying. I had to go there a few times. What really happened was back side drain pipe was completely detached from the drain itself. It's fixed now.
Old Nov 2, 2017 | 03:37 PM
WhiteTCH2011's Avatar
Hi, please elaborate on what or where this "back side drain pipe" is? I am having the same problem where water is pooling in the back seat of driver's side carpet. Thanks!
NateTheGreat
Jul 1, 2017 04:23 PM
rabkay
Mar 19, 2011 01:03 PM
Freeze
Jan 19, 2007 11:34 PM
fullofbeans
Jul 5, 2006 09:41 AM
Jason
Hybrid & Related News
Mar 2, 2005 02:00 AM
