Camry 2009 12V Issues And Hybrid Battery Issues
Old Feb 6, 2021 | 05:55 AM
Harvey_2009's Avatar
Unhappy Camry 2009 12V Issues And Hybrid Battery Issues
2009 Camry Hybrid Black No Navigation With 222,222 Miles Bought It In 2009 It Wouldn’t Go Into Ready Mode In June. Started The Car Up 30 Minutes Later Car Was Dead. Another 30 Minutes Check Hybrid System Came On Still Wouldn’t Go To Ready Mode. Another 30 Minutes It Went To Ready Mode No Warning Lights. Jump Forward To September It Was Doing The Same Thing No Ready Mode Started The Car Up 30 Minutes Later Car Was Dead. Another 30 Minutes Check Hybrid System Came On Still Wouldn’t Go To Ready Mode. Another 30 Minutes It Went To Ready Mode No Warning Lights. Jump Forward To January No Read Mode Start The Car Up 30 Minutes Later Car Was Dead. Another 30 Minutes Check Hybrid System Came On Still Wouldn’t Go To Ready Mode. Another 30 Minutes Another 30 Minutes It Went To Ready Mode But The Check Hybrid System Check VSC Light And Maintenance Required Light Was On Washer Fluid Low Light Red Triangle Light ABS Light Tire Light Check Engine Light And A Battery Light For The Whole Last Two Weeks On Last Month. I See The Battery Going Down And Going Up To Quickly And The Engine Was Kicking In A Lot . The A/C Is Blowing Cold Air Only. So I Took Into A Toyota Dealership And They Want 115.95$ For The Oil Change 189.96$ For The Windshield Fluid Change 4,891$ For The Hybrid Battery 476.39$ For The 12V 199.97$ For The Tires 598.29$ For The A/C Repair. I Really Think The Toyota Dealership Is Rip Off Is You Ask Me.
P3004 131
P0A7F 123
P0A80 123
C1241 41 84
C1259 58 150
C1310 51 156
C2177
B1423
B1424
12V 8.03 OFF 13.43 ON
BB1 15.13
BB2 15.10
BB3 15.09
BB4 15.13
BB5 15.15
BB6 15.10
BB7 15.01
BB8 15.20
BB9 12.22
BB10 12.29
BB11 12.27
BB12 15.30
BB13 15.11
BB14 15.03
BB15 14.99
BB16 15.15
BB17 15.13
ALL RR AT 0.30
Old Mar 14, 2021 | 05:43 PM
jpezz's Avatar
2009TCH w/NAV bought 4/08
Default Re: Camry 2009 12V Issues And Hybrid Battery Issues
Is your 12V battery bad? Up to 6 months ago, my ORIGINAL 12V battery was fine. Then it started having problems which caused all sorts of car issues. So I bought an Optima from that online seller in California. It comes with full instructions for those of us not sure of ourselves. All the problems disappeared.
Having a 12V battery last 12 years before needing a replacement is great news. Knowing that it resulted in not having other problems any more was even better news.
Yes, your dealer is taking you for a ride.
Old Mar 15, 2021 | 08:46 AM
Absolutely no question the hybrid battery is bad. Blocks 9-11 are almost 3V below the other 14 blocks, and a low 12V can't cause this.
Extended sitting likely caused weak cells to self-discharge excessively.
$4800 for a new one isn't atypical. The lowest I've ever seen is $4300.
crod
Mar 14, 2021 05:50 PM
Sara Brown
Jan 31, 2020 06:35 PM
Tracy
Jun 26, 2019 10:45 AM
thomas1097
Oct 4, 2016 02:01 PM
Nuclearr
Feb 16, 2014 08:13 AM
