Bluetooth can you accept calls?
Old Oct 24, 2006 | 05:48 PM
cohort's Avatar
Default Bluetooth can you accept calls?
If a call comes in, can it go through the car? I can call out but it does not ring when calls come in
Old Oct 24, 2006 | 07:16 PM
ByronJames2003's Avatar
Default Re: Bluetooth can you accept calls?
You should be able to receive calls, especially if you can make them.
I have no problem with this at all.
What type of phone do you have?
Byron
Old Oct 24, 2006 | 07:50 PM
Big-Foot's Avatar
Currency-to-hydrocarbons
I read this post and had to go and try it.
I had my wife call me (I have a Sprint Treo 700P) and the caller-id detail showed up on the nav screen. I pressed the off-hook button on the steering wheel and it worked like a charm.
I continued the experiment to see what happened if I shut the car off. The Bluetooth remained connected to the phone long enough for me to pull the phone from my pocket and press the cancel button for the bluetooth and the audio functions returned to the phone itself.
The only problem;
As I've read elsewhere here - the Caller ID does not register the correct phone number.
Old Oct 24, 2006 | 08:34 PM
cohort's Avatar
Byron
I just got the Razor V3
WHen I get in the car do I have to turn the Bluetooth part of the phone on or something?
Old Oct 24, 2006 | 08:41 PM
cohort's Avatar
I went and played with it and answered my own question.
The car rings loud, wow.
Old Oct 25, 2006 | 05:18 AM
Orcrone's Avatar
The only problem;
When I shut off the car my phone will display "bluetooth sounds transferred to phone" and the transfer is done automatically. I just tell people there will be several seconds of silence.
I've had no problem with the caller ID on my phone (Verizon LG-8300).
The only thing I have not figured out is how to pick up an upcoming call on call waiting while I'm talking on the phone. I've hit the off-hook button but it didn't work.
Old Oct 25, 2006 | 06:25 AM
hamm3r's Avatar
You do know that there is a "Transfer Call" button on the NAV display, right? It will let you toggle the call back and forth between the bluetooth or the handset
Normally NO caller ID info shows on my screen (anyone know why?). When it occassionally does show up, it is correct.
Try the off-hook button on the phone itself. It should still be functional.
Old Oct 25, 2006 | 06:41 AM
Orcrone's Avatar
Thanks, I'll give that a try next opportunity I get.
Old Oct 25, 2006 | 09:19 AM
wcmack's Avatar
I had a tough time getting my phone (Treo 650 Verizon) to pair with the NAV system. I finally got it to work and then tried to transfer my in-phone address book, and could not. I did some research on the Verizon Wireless website, and came across a set of "compatibility matrices", like the one I have attached. Turns out transferring the address book is not possible from Treo 650 to the TCH system (supplied by Denso)
I don't know the provider for the phones you all use, but you may want to check the provider's website to see if they have something similar. It may help to know whether the phone you have will provide the feature you are hoping to use in the Denso system.
File Type: pdf
Old May 29, 2007 | 11:15 AM
pgw60159's Avatar
I have a new Verizon RAZR and the bluetooth works great for OUTGOING calls, but incoming calls get dropped with the "CALL TERMINATED BY NETWORK" showing up on the nav screen. I got a replacement phone when I told Verizon about this, but it does exactly the same thing... any help would be GREAT!!!
Curated Content Editor
Jun 25, 2013 04:50 PM
miketeri
Mar 15, 2013 11:57 AM
Mar 15, 2013 11:00 AM
WaltPA
Dec 12, 2006 05:00 AM
