Back up Camrea installation to the NAV unt (with pictures)
Old Jan 19, 2007 | 06:22 AM
  #31
MickeysPal's Avatar
Default Re: Back up Camrea installation to the NAV unt (with pictures)
Originally Posted by tnsig
Hey MickeysPal
Just out of curiosity where did you buy your camera, what model did you get and who installed it?
Once I get my TCH I'm considering getting it done too. I'm not skilled enough to do it myself
I didn't feel comfortable trying to install it myself either...
My Toyota dealer wanted $925 to install the camera. They were going to sublet the job to a local installer and then just markup the installer's price. I ended up dealing directly with the local installer, avoiding the dealer's markup.
I've got the Eclipse BEC-105 camera. It was supplied by / installed by Audio Express in Raleigh, NC. They charged me $645 (camera - $350, toycam interface - $60, labor - $200, shop parts - $5, tax - $30 = total - $645).
You could probably save $$ by ordering the camera on ebay and having a local car stereo shop install it for you. jabagri's instructions appear to be clear and concise.
Old Jan 19, 2007 | 06:27 AM
  #32
tnsig's Avatar
Thanks Walt...I'm here in east TN and thought you may have used a regional company to do the install...I'll probably also use a local company. Thanks for the info.
Old Jan 19, 2007 | 02:11 PM
  #33
tnsig's Avatar
Oh and I was also wondering where they/you got the Toyota interface? I would assume the interface allows the camera to connect to the back of the Nav unit? I called a local place and they said they would do it but I had to find the interface.
I was looking back through the DIY instructions in this thread and I didn't understand where the R10 connector came from? I wonder if that was the part that came from "an old computer"? Also after looking at the R10 connector I can see where the camera wires plug into the R10 connector but there are a bunch of other wires plugged into the connector and I haven't a clue where they came from and what they connect to . I guess if I could find the R10 connector (interface) I could have the local company put it together...
Old Jan 19, 2007 | 02:58 PM
  #34
jagbagri's Avatar
.....I was looking back through the DIY instructions in this thread and I didn't understand where the R10 connector came from? I wonder if that was the part that came from "an old computer"? Also after looking at the R10 connector I can see where the camera wires plug into the R10 connector but there are a bunch of other wires plugged into the connector and I haven't a clue where they came from and what they connect to . I guess if I could find the R10 connector (interface) I could have the local company put it together...
If you hav the factory NAV the R10 connector shown in the picture (bunch of other wires plugged into...) is already there pluged into the socket at the back of your nav. The rest of those wire are connectors for your voice activation, microphone and the steering wheel controls. You just add the four wires from the camrea in the shown pins and plug it back into the back of your nav unit.
Old Jan 19, 2007 | 03:17 PM
  #35
tnsig's Avatar
Thanks Jag...you had mentioned in the DIY that you needed some wires from an old computer. What did you use those for?
Old Jan 19, 2007 | 09:15 PM
  #36
nautiduck's Avatar
Gang, my TCH arrives in about a week. Why are you installing cameras in your cars? The rear visibility seemed OK to me. Is there a blind spot or are you gadget geeks?? Mind you I am a gadget geek myself so no offense!
Old Jan 19, 2007 | 10:26 PM
  #37
Ham's Avatar
Ham
jagbagri,
One more question for you, when you tried to get the camera to display while in drive, did you try going to the service screen and enabling the overide that allows you to manipulate the nav system while driving?
I am wondering wether if the camera is supplying video to the nav and the nav is in overide the nav system will display the camera video despite being in drive.
Thanks again for your time and experimentation,
Ham
Old Jan 20, 2007 | 06:23 AM
  #38
MickeysPal's Avatar
When my installer first attempted to install the camera, they realized that the connector on the end of the camera cable would not fit into the R10 connector on the rear of the nav unit. They called someone (I don't know who) for tech support, and learned there is a "Y" cable (toycam interface) that plugs into the R10 connector on the nav unit. The "Y" cable then connects to the original cable plugged into R10, and to the connector on the end of the camera cable. My installer ordered this cable via overnight delivery so that the installation could be completed.
jagbagri installed his camera without using the "Y" cable. He used 4 wires that he removed from an old computer CD-ROM cable and spliced to the wires in the camera cable. He then inserted the 4 wires into the existing R10 connector. (see picture below)
fyi - The camera is available from Crutchfield. http://www.crutchfield.com/S-KxigcNy...sp?i=099BEC105. If you contact Crutchfield, they may have more info about the "Y" cable (aka toycam interface). Or, if you want, I can email you the name and phone number of the folk that did my camera installation.
Old Jan 20, 2007 | 06:33 AM
  #39
MickeysPal's Avatar
Originally Posted by Ham
jagbagri,
Ham
I can't answer your question... My nav level is 6.1. I am not aware of any way to to put a 6.1 nav unit into override.
Old Jan 20, 2007 | 06:35 AM
  #40
tnsig's Avatar
Hey Walt...check you PM's . Thanks for the info
