Another Hidden Menu
Old Dec 26, 2006 | 01:29 PM
hamm3r's Avatar
Default Re: Another Hidden Menu
Originally Posted by Paulgw
See last paragraph of message 1
Thanks.
Old Dec 26, 2006 | 07:50 PM
Bigsk8r's Avatar
jabagri,
Thanks for the heads up on the BT. I went to +1 and everyone says it sounds great.
Bigsk8r
Old Jul 16, 2007 | 08:48 AM
stevil's Avatar
Lord of Time and Space
Any way to access this BT setting without the nav system?
Old Sep 4, 2007 | 01:09 PM
OmegaOmega's Avatar
Originally Posted by jagbagri
The 'harder way' is to turn the ignition ON (NOT start just ignition on, foot off the barke and press ON twice) then hold the INFO button and turn the lights on and off 3 times (not auto but off and on). this will take you to the same diag. menu. But I'm affraid I'll burn the headlamps some day doing like this.. That's why I preffer te easier way described above.
I feel like with this method, you should also be able to click your heels three times and magically arrive home.
Old Sep 4, 2007 | 01:15 PM
nyc2socal's Avatar
Originally Posted by Bigsk8r
jabagri,
Bigsk8r
Interesting.. I found the volume too low when my wife calls, so I adjusted it to +1 (for the outgoing).. That only added distortion and "noise" so we're back at the default.. Rather have a low volume, than a noisy (screeches, and other artifacts)..
Old Sep 16, 2007 | 09:51 PM
ManchesterUnited's Avatar
Also, if you push and HOLD for about 15+ seconds the "blank" selection on the middle column of the another page of diagnostics after the 1 and 2 corner presses from the first hidden menu screen, you get yet another menu with some sort of data logging control. This is in a 2008 TCH with v6.1 map software (actually 06.05.12).
Has anybody found a menu for checking the XM signal strength?
Old Sep 24, 2007 | 03:02 PM
  #27
tma654's Avatar
So how do I do this??
Does my car need to be in ACC, ON, or Running?
Can anyone give me a clearer explanation?
I have an 07 TCH, with 6.1
Old Sep 25, 2007 | 05:43 AM
  #28
rmorrow's Avatar
Read the first posting in this thread. All of the detailed instructions are there.
Old Oct 15, 2007 | 11:43 AM
  #29
KTLane's Avatar
blahhhhhh!
do you know if it works with the 7.1 disc?
I'll have to try it when I get home and see
Old Oct 15, 2007 | 12:38 PM
  #30
mikieboyblue's Avatar
I wish I had the 7.1 disc...maybe it has fixed some problems with the crappy map directions. Oh well....I'll wait a while longer.
