alarm syatem for TCH 07 and tire guage
I am looking to install alarm system on my tCH 07 because theif have broken in to my tCH and I want to prevent such in future.
I am also looking for a nice tire pressure monitering device or something which you call tire gauge or something like that to check for tire pressure and see if the tires need air.
any links and recommendations?
thanks
thanks
Re: alarm syatem for TCH 07 and tire guage
Each of your tires (including spare) has a built-in tire pressure monitor. You will get an indicator on the dash when one of your tires is more than a few pounds low. However, you still should get a simple pressure gauge and check your tires from time to time. They are only a few bucks at the local car parts store.
I'm not an expert in alarms. However, the entry system for the TCH is complex. If I were buying an system, I'm sure that I'd end up with the genuine Toyota Alarm. Unless you are real handy, you'll probably end up getting it from a dealer and having it installed there.
I found a rather accurate digital readout air gauge at walmart automotive. It cost about $10 or so dollars. I like it as it lights up and makes it easy to read the pressure numbers. This is the first gauge I have ever seen that don't seem to allow any air to escape when your checking the tires. You do have to press the soft rubber button to boot up the gauge each time you test a tire. It only takes about 3 seconds though.
