Adding a subwoofer
Old Jan 7, 2010 | 09:04 AM
  #41
derekrice07's Avatar
Default Re: Adding a subwoofer
Ok, I know alot about the camry hybrid. I use to sell the cars for Toyota. Now my question is "How do you install an amp and sub?" I just need the directions, I have never installed an aftermarket system so it will be my first time.
Does anyone have directions that they will be willing to share with me?
Old Oct 11, 2010 | 03:46 PM
  #42
OregonGrown's Avatar
****, sorry about the size, here are smaller ones.
Old Oct 12, 2010 | 04:18 PM
  #43
Here are the dimensions flipped
Old Oct 13, 2010 | 03:51 PM
  #44
Hal A. Pino's Avatar
Oregon,
Thanks for sharing. I can't read the dimensions on your picture. Can you please spell them out? Thanks.
Also, how did you connect your amp to the system? Did you use a high pass system, meaning using the speaker inputs from the back speakers?
Hal
Old Oct 13, 2010 | 04:35 PM
  #45
I will get the dimensions tomorrow. To hook up the amp I used a LOC thingy off of the rear speaker wires coming from the amp under the passenger seat. To me, going off those wires was easier than the wires at the rear speakers in the trunk.
Bryan
Old Oct 14, 2010 | 10:41 AM
  #46
If I were to do it again, I would take 1/2" from the depth, as now it hangs over the edge just a little bit. The height is 5 1/4".:conf used: Sorry, fun with smilies.FxzRz.jpg
Old Oct 19, 2010 | 05:17 PM
  #47
talljetman2's Avatar
Question Re: Adding a subwoofer
That is awesome .. I have been thinking about adding a sub as well, not to 'overkill' the whole system, but just to fill in the 'missing gaps' on the low-end of the music/system.
I have a few questions about your set-up though:
- Where did you put your amp? Is it in the small space in-between the back of the rear seat and the hybrid battery cover?
- Are you noticing or having any sort of type of distortion? (Since the battery is right there). ..And...Is/Will the sub's magnet interfere with the hybrid battery or system at all? (I ask this since the last thing I want to hear is something like 'Oh your battery seems to have been damaged in some way...we won't cover it under the warranty anymore).
Other than that... Awesome! I will have to look into this a bit more - It's good to see someone utilized that space!
Thanks for the infos - I'm also curious to know if you have any pros/cons with your system now after installation and some use.
Thanks!
Old Oct 20, 2010 | 04:00 PM
  #48
Thanks!
Thank you! Here are the answers to your question:
The amp is under the drivers side seat.
It sounds good, no distortion or electrical noise that I have noticed.
I haven't thought about the magnet affecting the Hybrid system, nor have I noticed anything that would make me believe that something isn't working correctly.
I like the system alot now. The bass isn't overkill, but you can definately hear and feel low tones that the stock system lacked. Also, since I have the sub, I turned the bass level to neutral (the middle) so the stock woofers aren't having to handle as much bass, therefor I can turn the system up louder and not have any distortion or fear of blowing a speaker. I can turn it up to the mid forties and it still sounds great! Again, thanks for your compliments. Also, if you PM your e-mail I can send you the plans in a Google SketchUp file so you can see them more clearly.
Bryan
Old May 14, 2019 | 08:35 PM
  #49
Zekeman's Avatar
I am responding to this ancient thread and likely most people having any interest have sold their TCH...not me.
I finally decided to build a custom cabinet and tap into the stock JBL system and install an amp and active crossover.
I decided that an under-seat cabinet would be a challenging cabinet build because of interference so I decided to build a cabinet which sits behind the console and houses an 8” single sub. I also decided on a sealed cabinet which I prefer. The idea is that, when finished, it exists as a sort of rear extension to the console. I rarely have any people in the rear seat let alone three. I am now searching for carpet (color) with which to cover the cabinet.
The sound is very nice. In fact I have to dial down the crossover output quite a bit to balance the subs output. I used a Dayton 8” subwoofer which is being driven by an Alpine power amp in bridged configuration. I have an active crossover in the glove.
i will post a pic when I finish the cosmetics.
MagneticPearl06
Mar 19, 2009 08:49 PM
niteflyp38
Mar 15, 2009 12:04 AM
spiffnme
Mar 25, 2007 11:13 PM
sfam
Sep 7, 2006 08:44 PM
zimbop
Feb 19, 2006 02:27 PM
