Adding a subwoofer
Old Feb 27, 2008 | 01:47 PM
reignofjerm's Avatar
Default Re: Adding a subwoofer
I have a Rockford Fosgate P600.1bd.
http://www.rockfordfosgate.com/produ...7&locale=en_US
Old Feb 27, 2008 | 06:16 PM
dledeaux's Avatar
Ok, now I need to jump in.
How did you wire it into the stock system? I didn't think there were any outputs on the head unit.
Old Feb 28, 2008 | 06:25 AM
mikieboyblue's Avatar
That was my next question....along with....where are you powering it from? The 12V battery?
Old Feb 28, 2008 | 08:17 AM
You splice in from the rear speakers. The only bad part about that is that you can't control the sub seperate from the rest of the speakers. It's not the ideal situation.
Answer to second question is, I'm powering from the 12V. It's the same as any car battery. My amp does hit pretty hard, so I'm thinking of adding a capacitor.
Old Feb 28, 2008 | 11:16 AM
Interesting...thanks...I do have a spare Pioneer 800w amp, sub, and box....I can't decide if I should sell it all or use it!
Old Feb 28, 2008 | 11:37 AM
flopshot's Avatar
I'm going to order the Blaupunkt THB-200A enclosed/powered subwoofer and will mount it directly behind the rear seat on the driver side, since there is a small gap in there that is useless for anything else.
Old Feb 28, 2008 | 01:47 PM
That would be the ideal situation, but I'm a bass junkie, and while these small boxes really fill out your factory system, they don't really hit as hard as I'm looking for. I'm thinking of just doing a smaller box. Im leaning towards the Infinity Kappa series.
Old Feb 29, 2008 | 04:18 PM
raven77's Avatar
Dont waste your money on a cap. They are waaaay over rated and the WRONG way to fix any cars electrical system! Put that money into a bigger alternator if anything...
Old Feb 29, 2008 | 04:32 PM
I'm using the Rockford Fosgate 600.1bd
Old Feb 29, 2008 | 04:44 PM
raven77's Avatar
And I'm using 2 Kicker SX900.2's and 1 Kicker SX600.2. I have 00 Gauge wire run to my power dist. block.
I dont have a cap and my lights don't dim at all when the bass hits...
