Adding Brake fluid to reservoir
Old Jul 6, 2018 | 07:20 AM
srivenkat's Avatar
Default Adding Brake fluid to reservoir
Hi All,
The dealer replaced the brake reservoir at 98K miles, as part of the service campaign for the reservoir filter clogging up. At that time the dealer's invoice showed 5 qts of fluid being used, which I assume means a full fluid flush/replacement was performed.
Now the car is at 122K miles and the fluid level in the reservoir is about a half inch below the minimum. Front pads are at 6 and the rear at 7; the rears were replaced a few years back.
Would it be OK to quickly open the reservoir top and add some fluid from a freshly opened container to bring it up to the Max level?
Also, I see the top of the reservoir doesn't have a flexible accordion style cap. So, I am wondering if the void caused in the reservoir by worn pads is replaced by air, and if so where does the air come from?
Thanks in advance.
Old Jul 13, 2018 | 08:54 AM
Pete4's Avatar
Default Re: Adding Brake fluid to reservoir
I would make sure I have right break fluid, either Toyota, or some exact replacement and keep it at least at the minimum, but I would absolutely check for leaks: my car shows close to full when all pads new, but I think it never goes bellow minimum when pads wear off. Of course dealer may have not put right amount of fluid in the first place, but keep an eye on it.
PS. I'm assuming both reservoirs are same level and it's not dirty filter issue per Toyota TSB.
Old Jul 13, 2018 | 11:50 AM
srivenkat's Avatar
Thanks. It actually turned out that the fluid level is at Max. It was some sort of an optical illusion that caused there level appear to be at Min. The real level is visible if I put my hand on the side of the reservoir and look.
cje2310
Aug 30, 2019 11:45 AM
Feebz13
Mar 12, 2016 11:51 AM
trekwars2000
Jan 10, 2014 07:38 AM
McGyver
Nov 2, 2009 04:48 AM
bigbearballs
Feb 17, 2006 06:23 AM
