A Brake Upgrade Report
Old Sep 29, 2009 | 08:04 PM
McGyver's Avatar
Default A Brake Upgrade Report
OK, I'm done. New slotted, drilled and chamfered, directional rotors, zinc plated and a set of ceramic pads are installed. I hit a few surprises along the way:
1. You absolutely cannot bleed this brake system in a conventional manner, without a Toyota Intelligent Tester connected. There are currently 3 of them on eBay, probably hot, that are going for around $3,000.
2. My brakes were in pretty rough shape with a lot of rust.
3. My pads were at 10.2 -10.6mm versus nominal 12mm (11.6mm actual) when new, so my estimate of 90% life was reasonably accurate.
4. My guide pins and sliders looked like they had 100,000 miles of neglect at only 37,000. The grease was sludgy, black, and the pins were starting to gall in some spots, very surprising/alarming.
I didn't bother miking or dialing the OEM rotors, sunlight was fading and they had to be forced off the hub with forcing screws. There was substantial rust in the hub area. I attribute that to weekly car washings, where I really get the brake dust off the wheels. I can say I have never applied water to a hot rotor...that would be dumb. But I do get plenty of water in and around there and it seems to have taken a toll.
I cleaned the pins and blew out the sliders ans best I could and re-packed all with Volvo silicone brake grease. I wire-brushed the hubs and treated the surface with WD-40 and a thin coat of anti-seize around the hubs and thrust face where the rotors match up.
The pistons retracted without a fight and the seals looked OK, save for some crusty material that I brushed off and removed with solvent.
Once the mating parts were restored, everything went together beautifully. The rotors look awesome and in my short road test, seemed to perform as expected.
With the pistons both pushed back into their stops, I took the opportunity to drain the MC Reservoir, ghetto-style, with a coil of 1/2" clear tubing, one end in the res, the other end in my mouth. Remember, bleeding is not an option. After 5 or 6 hearty inhalations, I most of the fluid out. It was slightly dark. And it left a foul taste all the way down my trachea. I don't recommend this procedure. With more time, I would have dug out my hand pump.
I replaced the fluid with approximately 500ml of Synthetic brake fluid with a wet boil point of near 400F and after gently re-seating the calipers and new pads in a non-powered state, I went for a short road test.
The Hi-Perf Rotors and ceramic pads behaved better than I imagined, albeit with a distinctive grunt as the rotation comes to a stop. I found this to be the case on other cars I have done this upgrade to in the past. It tends to get better as the pads wear in.
But the braking effectiveness is phenomenal!! And there seems to be no conflict with the regen/friction thresholds, it works as well, if not smoother than the OEM set up. No DTC's were set either.
This job would have cost anywhere form $800-$1,000 at the dealer, with inferior OEM parts.
I'm out exactly $135, including the parts, the hi-test fluid, 2 beers, and one professional opinion from a factory-trained technician moonlighting on the Internet, one pinched finger and about 90 minutes of my time.
Old Oct 27, 2009 | 08:54 AM
cmartinez95's Avatar
Default Re: A Brake Upgrade Report
So you only replaced the fluid in the reservoir and didn't actually bleed the system?
Old Oct 27, 2009 | 10:13 AM
wwest's Avatar
You can bleed the brake calipers in the conventional manner.
The ABS pumpmotor manifold assembly can be "bled" via lifting both drive wheels off the ground and "driving" forward. TC will activate which will circulate the fluid. If there is no bleed valve at the ABS manifold that use the one at the nearest wheel. And always bleed the ABS manifold FIRST.
"....Removed with solvent.."
You cleaned the rubber piston boot/bellows with a solvent. Soap and water would have been a much better choice and you wouldn't now have the worry of rubber disintegration.
Never, NEVER use this procedure.
"...drilled and slotted.."
And all that accomplished was a lessening of braking HP due to the lowered CSA of the pad/rotor contact area.
Old Oct 27, 2009 | 04:46 PM
UWAdventurer's Avatar
You could have used the gravity method to drain the fluid. Fill a hose with fluid, put one end below the reservoir, the other end in the bottom of the reservoir, release the end lower than the reservoir to drain it.
Did you crack the caliper drains before pushing the pistons back in?
Old Oct 31, 2009 | 08:07 AM
McGyver's Avatar
Well that, and the front end stopped shaking during a high speed haul down. ...and they were 80% less money than OEM.
I did not know about the brake bleeding spoof with the wheels off the ground. That is a fantastic idea! Thank you!
Old Oct 31, 2009 | 08:10 AM
McGyver's Avatar
No. I was apprehensive about opening the system at all for fear that a pressure differential would set a code or cause some issue. With a little head room in the reservoir I moved the pistons back a little at a time until they bottomed.
Old Nov 1, 2009 | 10:18 AM
I would be afraid of pushing dirty fluid back through the ABS system. This has not been an issue? Usually that is not acceptable.
Old Nov 2, 2009 | 04:48 AM
McGyver's Avatar
It wasn't dirty in terms of suspended particulate matter. It was a little dark. Somehow it circulated back up to the reservoir on its own, whereupon I removed it.
You might be thinking of pushing the brake pedal down while a bleed valve is open... that's a big no-no due to silt accumulation at the bottom of the MC piston stroke.
I know it is less than ideal. But since I never let things get to a bad state of repair, I feel that a simple fluid exchange on a regular basis will be fine. This approach has served me well with 4 or 5 vehicles over the past 25 years. Never had a problem.
Eggsaladsndwich
Feb 10, 2014 04:48 PM
rburt07
Feb 5, 2010 03:47 PM
