2007 Camry Fuel door
Old Sep 2, 2018 | 09:58 PM
HVMercado's Avatar
Default 2007 Camry Fuel door
So after 12 years, I am starting to have minor annoyances with my Camry. The biggest one is the fuel door, refuses to open sometimes. The solution is I open the trunk and open the door that way.
I can’t seem to find any information on how to troubleshoot my issue. Has anyone had a similar experience, or can anyone offer any advice.
T.I.A.
Old Sep 3, 2018 | 07:10 PM
Pete4's Avatar
Default Re: 2007 Camry Fuel door
Mine is working fine, but I would put some penetrating oil on all moving parts if had your problem (actually I did spray mine couple times over the years in past). If that didn't work, maybe replace the whole linkage or lock, depending whats binding, either yourself or maybe mechanic, shouldn't cost that much I hope.
But frankly, if this is your biggest problem you have on 12 year old car, I would consider this pretty good.
Old Sep 4, 2018 | 11:25 AM
haroldo's Avatar
Most likely your spring is broken https://www.bing.com/search?q=fuel+door+spring&PC=U316&FORM=CHROMN
It's a 35 second repair
jimmy1
Jan 31, 2019 07:27 AM
haroldo
Feb 10, 2012 06:54 AM
mj662@mac.com
Apr 7, 2010 05:53 PM
HyCAMBill
Apr 13, 2009 06:46 PM
IMAhybrid
Apr 16, 2008 03:36 PM
