12 Volt Battery Replacement / Upgrade on a 2007 Toyota Camry Hybrid with photos
Old Dec 10, 2013 | 06:13 AM
  #131
brianrounds's Avatar
Default Re: 12 Volt Battery Replacement / Upgrade on a 2007 Toyota Camry Hybrid with photos
Then make a battery with a vent tube hook up for Toyota Hybrids or at least an option. I just bought one of your Yellow Top Optima batteries for $225 and wow no vent tube. Seems easy enough.
Old Dec 11, 2013 | 05:46 AM
  #132
OptimaJim's Avatar
Former Vendor
Brian, I appreciate your feedback and will certainly forward your request to the appropriate parties.
Jim McIlvaine
eCare Manager, OPTIMA Batteries
www.pinterest.com/optimabatteries
Old Dec 11, 2013 | 06:16 AM
  #133
Since i'm at it... I would make a pocket in the plastic molding the temperature sensor can slip into so people don't have to jerry-rig a solution. It would make your battery a viable option for all Hybrid users.
Old Dec 11, 2013 | 08:26 AM
  #134
GeorgiaHybrid's Avatar
Brian, that sensor really needs to be hot glued onto the battery to make sure it has a good. heat conductive path to the battery case. A "pocket" would not do that.
Old Dec 11, 2013 | 08:31 AM
  #135
I get that now and does make sense. That is not what I did - I the sensor semi-wedged under the medal holding bracket held in place by two zip ties. It is firmly in place and pressed against the battery.
All i'm saying is it would be nice that some of the higher end battery manufacturers make a spot for the sensor to be placed into with something to hold it in place. Seems simple enough and not to much to ask for $225. ???
Old Dec 12, 2013 | 08:14 PM
  #136
ukrkoz's Avatar
I have this waiting for the time to come for battery replacement:
Those are 90 degree polyurethane tubes, with inner channel. We use them for suction sockets for amputees. I'll cut short tips off, roughen wide bases with sand paper provided, and bond with polyurethane resin atop of factory Optima vents. From that on, it is POC to have factory vent connected to them.
But my battery is still doing OK. Not sure, maybe around spring time or whatever.
Old Dec 16, 2013 | 07:36 AM
  #137
hybrid newbie's Avatar
Captain Jim,
It is hard to tell in the last picture, what is the sensor actually touching?
Old Dec 17, 2013 | 06:44 AM
  #138
ukrkoz's Avatar
Originally Posted by hybrid newbie
Captain Jim,
He jammed it between the metal bracket and battery top lid. It's directly on battery, well, on a paper sticker on battery. To prevent it from sliding out, he secured it with a zip tie. You can use glue gun and run plastic glue around sensor but I think his way is quite fine.
Old Dec 23, 2013 | 06:39 AM
  #139
johnl222222's Avatar
well We returned home from a long 1180 mile trip late last night and parked our 07 Camry H , this morning Nothing notta, and the parking lights were on strange we didn't leave anything on at all. no juice from 12v batt no horn, no power locks no nothing. i am GUESSING it is the 12v batt since its OEM and we took delivery of the car aug 06 7 years not so bad.
Not for sure but hopeful that is the problem anyone else have the same issues?
Old Dec 23, 2013 | 06:48 AM
  #140
That's what mine did too. I followed the posts on here and purchased the suggested battery from Auto Zone for $229. And we're rolling again.
