07 TCH With nav & override :-)
Old Jun 28, 2007 | 03:08 AM
wilsons66604's Avatar
Led-footed HyBrid geek
Default Re: 07 TCH With nav & override :-)
Originally Posted by redwings7907
Where can i locate the fuses for the radio?
The fuse/s for the radio are located in the fuse box under the hood. Check your manual.
I only pulled one fuse (don't recall which one) and I didn't loose any settings on the system.
Old Jun 28, 2007 | 05:40 AM
mikieboyblue's Avatar
Pop the hood, mid-back right hand side.
Old Jun 28, 2007 | 05:41 AM
Radio 1
Old Jun 28, 2007 | 07:25 AM
greyghostTCH's Avatar
Ditto on the fuse, worked for me. I think it's #15, pulled it for about 2 minutes and there is a super handy little fuse pull tool attached to the underside of the fuse box cover. Thanks Toyota!
Old Jun 28, 2007 | 06:22 PM
finbib's Avatar
The only fuse you need to pull is under the hood. I can't remember the number, but the fuses are clearly marked on the inside of the cover. The fusebox is on the right hand side of the engine compartment.
Old Jun 29, 2007 | 01:39 AM
redwings7907's Avatar
SUCCESS!! thanks so much to all of you for your savy. after three failed attempts, i finally made my hybrid nav dvd on my iMac G5 after downloading a program called dragon burn (reccomended by a co-worker) and taking advantage of the free trial version. i inserted the burned dvd into the nav, up popped the map with my current location. i tried the override, no luck. so i removed the fuse and reinserted it after a few minutes, i tried the override again, and volla.
btw...it's not fuse #15, it's a 15 amp fuse. thanks again. i couldn't have done it without you!
chris_h
Aug 2, 2013 12:18 PM
Zoom On
Apr 22, 2007 11:06 AM
schmidtj
Dec 7, 2006 06:00 AM
blochga
Nov 27, 2006 02:57 PM
resa_80
Oct 5, 2006 06:54 PM
